Difference between AWD and FWD '03 engines?
Posted: Tue Apr 08, 2008 2:45 am
by Zeromus-X
I haven't had any luck finding an engine for my Vibe yet but it appears there are a ton of AWD engines. Any idea how much of an issue it would be to fit an AWD into a car that had a FWD engine? I'd think there wouldn't be much difference, but I know they have different HP ratings. They're both listed as 1ZZ-FE though.
Re: Difference between AWD and FWD '03 engines? (Zeromus-X)
Posted: Tue Apr 08, 2008 5:38 am
by ramenboy...
i could be wrong ( i often am) but i think they're the same engine. the drop in horsepower i think is in the weight of the awd system and the exhaust configurationgood luck
Posted: Tue Apr 08, 2008 5:41 am
by BlueCrush
Yup same engine
Re: Difference between AWD and FWD '03 engines? (BlueCrush)
Posted: Wed Apr 09, 2008 2:03 am
by Whelan
AWD refers to the transmission, not the engine. Therefore any engine will work except the 1.8L 2ZZ from a XRS or GT.
Re: Difference between AWD and FWD '03 engines? (Whelan)
Posted: Tue Apr 22, 2008 6:05 am
by THE VIBERATOR
Yes any engine except the 2jz engine will work. The FWD and AWD Vibes have the same 1zz-fe engine, but the FWD produces more horsepower....125 horsepower stock. Pontiac claims 130 but thats not true. If you want to be racing your car, go for the FWD..its lighter and will produce better results. But either way, 1.8L 4 cylinder engines are easily the best engines to modify. There's much more space.
Posted: Tue Apr 22, 2008 10:27 am
by tnpartsguy
any 1zz from a Vibe (AWD, FWD) or a Matrix, or a Corolla with a 1zz will work. The 2zz from the GT won't work.The lower HP rating for the AWD is due to the routeing of the exhaust system.
Re: Difference between AWD and FWD '03 engines? (THE VIBERATOR)
Posted: Tue Apr 22, 2008 3:57 pm
by Celtic_Curse
Quote, originally posted by THE VIBERATOR »Yes any engine except the 2jz engine will work. The FWD and AWD Vibes have the same 1zz-fe engine, but the FWD produces more horsepower....125 horsepower stock. Pontiac claims 130 but thats not true. If you want to be racing your car, go for the FWD..its lighter and will produce better results. But either way, 1.8L 4 cylinder engines are easily the best engines to modify. There's much more space.Hello hate to start an old debate but there was some discussion that the '03 1zz rated at 130HP by Toyota and GM was actually under rated due to the Celica GT sharing the same engine and having 140HP and wanting to keep the Celica from losing sales. One member actually dyno'd his 03 and with the usual loss in transmission it looked like they had been underated.I am still of the opinion that the 03 1zz was underated.
Re: Difference between AWD and FWD '03 engines? (Celtic_Curse)
Posted: Tue Apr 22, 2008 11:56 pm
by kevera
Quote, originally posted by Celtic_Curse »I am still of the opinion that the 03 1zz was underated. 2zz was the only change with the addition of an air pump in 04.So the 1zz was the same all around,and the 1zz celica has a better header than 1zz's used in Corollas,trixs and Vibes.So I say no to that.
Posted: Fri Apr 25, 2008 1:17 pm
by THE VIBERATOR
The vibe engine isnt underrated. It's overrated. The celica GT has overall better components, thus the 140 horsepower rating. The celica is also lighter. I raced a stock celica GT (automatic). I had my short ram and a throttle body spacer and we started from a dig and did a quarter mile. My first gear pulled on him by 1 and a half cars. Then from second gear until the end, he stayed a car and a half behind me, meaning we were both pushing 140 horsepower. My intake gives me 7, and the spacer gave me 8 horse and 10 torque.
Re: Difference between AWD and FWD '03 engines? (ramenboy...)
Posted: Fri Apr 25, 2008 2:56 pm
by Psychobroker
Quote, originally posted by ramenboy... »i could be wrong ( i often am) but i think they're the same engine. the drop in horsepower i think is in the weight of the awd system and the exhaust configurationgood luckBingo. Well, it's also probably tuned a little different.
