CG-Lock upgrade stock seat belts
Posted: Tue Apr 08, 2008 12:00 am
by northvibe
Anyone ever use one? Ive heard they are great for autox, rally, etc. if you dont want/cant afford to spend on a full racing harness setup. I was going to order 2 for myself (both front seat's). I also may have a coupon code to save a couple bucks....http://www.cg-lock.com/index.htmlhttp:/ ... stall.html
Posted: Tue Apr 08, 2008 1:27 am
by Sublimewind
Ever had a chance to use a 4pt harness? If not, it's nothing the same... Using a 4pt you HAVE to have you and your seat set up properly or you can't reach anything... Not a bad concept, but to market it as a "cheap" alternitive to a 4pt is just silly..
Posted: Tue Apr 08, 2008 2:43 am
by AKLGT
I have 2 3 pt harnesses (bolts right up to existing seat belt bolts or anchors). I don't want a roll bar or harness bar, so the 3 pt works great for me.
Re: (AKLGT)
Posted: Tue Apr 08, 2008 3:17 am
by Mavrik
it I didn't have a 3pt harness from the LGT... those would be tempting.
Posted: Tue Apr 08, 2008 3:21 am
by northvibe
well yeah its a cheap quick easy fix. I dont have the time nor money to dump into a half rollcage to do a real 5 point harness.
Posted: Tue Apr 08, 2008 3:33 am
by northvibe
donde esta the 3 point harness....any pics too?
Posted: Tue Apr 08, 2008 3:51 am
by AKLGT
actually, i don't think i have any pics. :lol:
Re: (AKLGT)
Posted: Tue Apr 08, 2008 4:23 am
by Whelan
I'm a little lost on how a piece of metal that essentially straps your waist down should cost $50. It seems like something that could be fabricated and made for $5
Re: (AKLGT)
Posted: Tue Apr 08, 2008 4:52 am
by Mavrik
Quote, originally posted by AKLGT »actually, i don't think i have any pics. :lol:thats a first LOL
Re: (Whelan)
Posted: Tue Apr 08, 2008 5:42 am
by northvibe
Quote, originally posted by Whelan »I'm a little lost on how a piece of metal that essentially straps your waist down should cost $50. It seems like something that could be fabricated and made for $5It locks the seat belt from moving. you know normal driving you can pull your seat belt and stuff, it only locks when you jam on the brakes. This locks it all the time when its used.
Posted: Tue Apr 08, 2008 1:06 pm
by northvibe
I just put my order in, for half the price of 1 harness that can really only be used during a autox i got 2 cg-locks that can be used all the time if i want and I can upgrade later. I would rather have a harness bar if i got harnesses anyway....
Re: (northvibe)
Posted: Tue Apr 08, 2008 10:20 pm
by Sublimewind
Quote, originally posted by northvibe »well yeah its a cheap quick easy fix. I dont have the time nor money to dump into a half rollcage to do a real 5 point harness. You don't need a cage for a harness.... You don't even really need a harness bar... all a harness bar does it hold the belts horizontal so you can mount the back end to the stock front locations, allowing you to have use of that position in the back seat.... Otherwise, the back end of the harness just attaches to where the rear lower belts attach...
Posted: Wed Apr 09, 2008 12:46 am
by northvibe
yes but in a real accident that harness with out a harness bar will/can hurt your back spine. So until I get a harness bar these should work great.
Re: (Sublimewind)
Posted: Wed Apr 09, 2008 1:12 am
by Mavrik
Quote, originally posted by Sublimewind »You don't need a cage for a harness.... You don't even really need a harness bar... all a harness bar does it hold the belts horizontal so you can mount the back end to the stock front locations, allowing you to have use of that position in the back seat.... Otherwise, the back end of the harness just attaches to where the rear lower belts attach... Depending on the style of your seat, you may need the harness bar.
Re: (Mavrik)
Posted: Wed Apr 09, 2008 1:52 am
by Kamikaze
for autoX we always flipped the seatbelt three times latched and then pulled, it put's you in the seat and won't unlock... at least prior to 2002 cars... haven't tried it since b/c I don't auto X anymore...basically did the same thing that these things do, except they probably do a better job.
Re: (Mavrik)
Posted: Wed Apr 09, 2008 2:10 am
by Sublimewind
Quote, originally posted by Mavrik »Depending on the style of your seat, you may need the harness bar. That's true, shoulda mentioned that..
Re: (Kamikaze)
Posted: Wed Apr 09, 2008 3:30 am
by Mavrik
Quote, originally posted by Kamikaze »for autoX we always flipped the seatbelt three times latched and then pulled, it put's you in the seat and won't unlock... at least prior to 2002 cars... haven't tried it since b/c I don't auto X anymore...basically did the same thing that these things do, except they probably do a better job.I did that in the Vibe and in the STi. I would twist the seatbelt about 3 times after locking it and then buckle it into place. I sure didn't move. Couldn't breath well either but yet... who can't hold their breath for 34 seconds LOL
Re: (Mavrik)
Posted: Wed Apr 09, 2008 12:12 pm
by Kamikaze
Quote, originally posted by Mavrik »I did that in the Vibe and in the STi. I would twist the seatbelt about 3 times after locking it and then buckle it into place. I sure didn't move. Couldn't breath well either but yet... who can't hold their breath for 34 seconds LOLif you can't breathe.. you just drive faster.
Posted: Thu May 15, 2008 5:12 am
by northvibe
well so far so good, these work great and a friend with them that autox's loves them too. cant wait for the sun to stay out so i can toss some corners.
Posted: Sat May 17, 2008 3:02 pm
by Celtic_Curse
I have the G-Lock too and its great rally holds you down for what it is. It claims 80% of the holding power of the harness and I believe it. Money well spent.
Posted: Thu Jul 10, 2008 1:26 pm
by northvibe
well I've used them autox'ing and road rally'ing in the twisties and they hold you the heck into your seat. Well worth the little money and easy install. I'd get them for all my seat belts but new passengers dont get how to use them :/ "lever goes down then belt..no hold it normal..wait flip, no the other way, down not up, aahhh let me do it..ok ok you got it."
