Idle Speed on '03 GT
Posted: Mon Apr 07, 2008 11:17 am
by slide13
My '03 GT idles at about 1200rpms, which seems a little high to me. It has a KN Typhoon intake on it that the previous owner installed, not sure if that would do anything. Does it/can it be adjusted to be lower? What should it idle at?
Re: Idle Speed on '03 GT (slide13)
Posted: Mon Apr 07, 2008 11:25 am
by kevera
Are you driving around with your air conditioning or defroster on,that will bump up idle speed(does turning on your air/defrost raise your idle?).You can't manually adjust it without throwing a cel light.If you have a smooth idle I'd leave it.
Posted: Mon Apr 07, 2008 11:32 am
by slide13
No AC or defroster....not even running the fan usually. It idles very smooth and is pretty consistent at 1200rpm. I guess I'll just leave it. I'll have to try turning on the AC next time I'm in it to see what that does to the idle speed.
Re: (slide13)
Posted: Mon Apr 07, 2008 11:38 am
by kevera
Just see if it makes a difference.If it doesn't then your IAC valve is either stuck open a bit or being sent the wrong signal.
