More Powerful Dome light Bulbs
Posted: Wed Mar 26, 2008 2:37 pm
by VforVIBE
Any options on how to make them betta, stronga, and generally brighta?
Re: More Powerful Dome light Bulbs (VforVIBE)
Posted: Wed Mar 26, 2008 7:51 pm
by kevera
You can go LED,but I'm not sure it will be brighta.The bulb is # DE3175,and check out the 2nd one down,
http://www.superbrightleds.com/festoon.html
Posted: Wed Mar 26, 2008 8:33 pm
by Raven
Re: More Powerful Dome light Bulbs (Raven)
Posted: Wed Mar 26, 2008 11:13 pm
by VforVIBE
Thanks for the info guys, it's just one bulb per dome right?
Posted: Thu Mar 27, 2008 3:45 am
by ToolGuy
I found a bulb from a local auto store that was one watt larger. Same part nuber as ours just one watt larger. I also took out the old bulb and put a piece of real shiny foil tape in the middle of the socket for a reflector. Than re-installed the bulb. The tape I used is at the Home Depot or Lowes and is used to seal heating/AC vents and pipes. Real strong sticky back. I also added bulbs in the floor mat area. Tapped in through the dimmer switch. Those are nice to have on any vehicle...
