The right plugs
Posted: Sat Mar 22, 2008 3:08 pm
by vibe Freak
I just put these little bad boys in to day. Night and day difference I was running NGK's before and the car was ping under light acceleration and in the heat. Yes heat I live in AZ. So if you are not running these plugs get them in the car A.S.A.P. It idles much better and the acceleration is out of this world. Denso Iridium IK20 5304 set gap @ 0.8mm or 0.032”
Re: The right plugs (vibe Freak)
Posted: Fri Mar 28, 2008 4:27 am
by BLAQJAQ
Just to add a footnote here and give you guys another option:NGK G-Power Platinum Spark Plugs ZFR6Specifically built for direct ignition engines like VVTi.. The correct spec of spark plug to use for 1zz and 2ZZ!
