2009 Bolt Pattern
Posted: Tue Mar 18, 2008 1:28 am
by 09Red_Se
Haven't found an official source - however it appears the 09's now use a 113 (4.5") x 5 bolt pattern, vs the previous 100 x 5.Can anyone confirm an official source? Accessory stores in my area have no listing of the 09's as yet.
Posted: Tue Mar 18, 2008 2:47 am
by engineertwin2
113mm would be an odd number to use. I have no idea what they are...be sure to let us know when you find out.
Re: 2009 Bolt Pattern (09Red_Se)
Posted: Tue Mar 18, 2008 2:51 am
by BlueCrush
It's probably 5x114. That is much more common.
Posted: Tue Mar 18, 2008 3:00 am
by bull77
Quote, originally posted by 09Red_Se »Haven't found an official source - however it appears the 09's now use a 113 (4.5") x 5 bolt pattern, vs the previous 100 x 5.Can anyone confirm an official source? Accessory stores in my area have no listing of the 09's as yet.i actually asked 2 sales guys about this --- b/c I want to use my winter tires from my 06 with the 09 --- and they both said the new vibe is using the same pattern....don't quote me on that
Re: 2009 Bolt Pattern (bull77)
Posted: Tue Mar 18, 2008 3:56 am
by Mavrik
ask someone on here with an 09?
Re: 2009 Bolt Pattern (Mavrik)
Posted: Tue Mar 18, 2008 4:46 am
by Raven
At treadepot.com they list 5x100x16 or 17 for base Vibe, 5x100x18 for GT and 5x100x16 or 17 for AWD.
Re: 2009 Bolt Pattern (BlueCrush)
Posted: Tue Mar 18, 2008 5:25 am
by kevera
Quote, originally posted by BlueCrush »It's probably 5x114. That is much more common.With the 2.4 it has a 5x114 bolt pattern(same as Camry).Anything with the 1.8 has the 5x100 bolt pattern.We had this discussion on Wed,one of the guys just bought the 09 XRS,and we were checking wheels out.Strange but true.
Re: 2009 Bolt Pattern (kevera)
Posted: Tue Mar 18, 2008 6:55 am
by Sublimewind
Quote, originally posted by kevera »With the 2.4 it has a 5x114 bolt pattern(same as Camry).Anything with the 1.8 has the 5x100 bolt pattern.We had this discussion on Wed,one of the guys just bought the 09 XRS,and we were checking wheels out.Strange but true.That is exactly what they did the the WRX and the WRX STi.... 5x100 and 5x114 respectively.. ??
Re: 2009 Bolt Pattern (Sublimewind)
Posted: Tue Mar 18, 2008 8:08 am
by Mavrik
Quote, originally posted by Sublimewind »That is exactly what they did the the WRX and the WRX STi.... 5x100 and 5x114 respectively.. ??yeah but only 2005 STi and newer. 04 has 5x100 but they enlarged the hubs on newer models.
5 x 100 on base model
Posted: Wed Mar 26, 2008 1:56 am
by 09Red_Se
Just installed 16x7 5x100 40mm offset wheels on my 2009 base model with 1SB (SE trim) , so firsthand answered my own question I guess. Dealer was good enough to trial one to be sure at N/C.Anyone in Toronto area may want to checkout
allen@simplytire.com.He did a very throrough and careful install - centering rings, balance, and swapped TPS valves. Hand torque. Price was reasonable as well.416-916-9233 not afiliated with them at all - just a happy customer.
Re: 5 x 100 on base model (09Red_Se)
Posted: Wed Mar 26, 2008 2:43 am
by kevera
Quote, originally posted by 09Red_Se »Just installed 16x7 5x100 40mm offset wheels on my 2009 base model with 1SB (SE trim) , so firsthand answered my own question I guess. Dealer was good enough to trial one to be sure at N/C.. That was mentioned in an earlier post1.8=5x1002.4=5x114Strange but true
Posted: Fri Jun 27, 2008 8:14 am
by MountainMax
Dam, I was hoping to use my old winter tires/rims on the new vibe too, but i have the 2.4 ordered so looks like I will need new wheels too, anyone what to buy the old ones, lolso the 2.4 even on the base model as an upgrade has the 114?
Re: (MountainMax)
Posted: Wed Jul 16, 2008 4:43 am
by Waterlogged
Fudgecakes!Just purchased a used set of 2009 Matrix wheels "knowing" that they were all the same..... Anyone need a set of 2009 Matrix 17" OEM rims/tires in the Seattle area?
Posted: Sat Oct 18, 2008 7:46 am
by jackw
Can I use VW195/65/R15 winter tires with steel rim on my '09 Vibe? They both have 5x100 bolt patterns but I don't know if there is anything else I need to know.
Re: (MountainMax)
Posted: Thu Oct 30, 2008 5:20 am
by mygsds
I need to find this out too. I have the upgraded engine but not the GT model. It has the 16" tires. On the GM site it only shows the base Vibe (which I have) having the 5x100 bolt pattern.If it has the 5x114 I might be able to use my old Grand Am snow tires as they are 5x114.Pat
Re: (mygsds)
Posted: Thu Oct 30, 2008 10:15 am
by kowell
Quote, originally posted by mygsds »I need to find this out too. I have the upgraded engine but not the GT model. It has the 16" tires. On the GM site it only shows the base Vibe (which I have) having the 5x100 bolt pattern.If it has the 5x114 I might be able to use my old Grand Am snow tires as they are 5x114.PatEvery models equiped with the 2.4L have a 5x114.3 bolt pattern.
Re: (kowell)
Posted: Fri Oct 31, 2008 4:30 am
by 09vibegt
Is a 5x114 wheel offset the same as a 5X114.3 ??? I know nothing about this subject so was hoping someone could help me out. I'm wondering is it is asctually the same wheel size any they just drop the ".3"?? Or are they two sizes actually different ?Appreciate any replies!Thanks
Re: (09vibegt)
Posted: Fri Oct 31, 2008 4:37 am
by kowell
Quote, originally posted by 09vibegt »Is a 5x114 wheel offset the same as a 5X114.3 ??? I know nothing about this subject so was hoping someone could help me out. I'm wondering is it is asctually the same wheel size any they just drop the ".3"?? Or are they two sizes actually different ?Appreciate any replies!ThanksSame thing
Posted: Thu Nov 06, 2008 7:11 am
by 09vibegt
Thank you!
Re: (09vibegt)
Posted: Thu Nov 06, 2008 7:44 am
by djb383
Actually, 5 X 114 has nothing to do with offset. Offset, is the distance between the backside of the wheel mounting surface and the center line of the wheel (positive offset or negative offset or zero offset). 5 X 114 is the bolt pattern - 5 bolts on a 114mm spread or spacing.
Posted: Tue Jul 02, 2013 2:51 am
by doublesharp
2009 2.4 Vibe has 5x114.3mm. There is no 5x114. When folks mention 114mm they are causing confusion to those who are not aware of the complete (and correct) size. Other GM have 5x115 but not the Vibe b/c it is really a Toyota Corolla with a new skin.
5x114.3mm is found on many other cars; such as Mustang, Eclipse, Lancer and Gallant. Just look around and you will find several options
