No blue/white wire on stereo? (M&T)
Posted: Mon Mar 17, 2008 4:30 am
I have a 2003 Vibe with Moon & Tunes and I am installing a new stereo unit. I read about the issues that some have had with the amplifier and the blue/white wire on the harness. The harness that I purchased has a blue/white and blue wire, however my stereo only has a blue wire for "power antenna or amplifier."What should I do? I am assuming that I would want to connect the head unit's blue wire to the blue/white wire on the harness since the blue/white wire is necessary to enable the amp. (In other words the blue and blue/white wires have the same function, the Vibe only uses the blue/white.) Or am I wrong? I simply want to make sure because I don't want to blow anything up :DThanks!
