				New Tires
				Posted: Wed Mar 12, 2008 11:20 am
				by Digger
				I just traded my stock tires for a set of Epic Tour 205/60/16s.  They are rated for 60,000 mile.   I got 40,000 out of the stock tires but they were well worn.
				Posted: Wed Mar 12, 2008 11:26 am
				by northvibe
				traded? or purchased? haha. yeah the stockers lasted over 50k on mine, but for 26k of that the company before me never had rotated them. luckily i didnt drive much at all in the winters back then....
				Re: New Tires (Digger)
				Posted: Wed Mar 12, 2008 11:43 am
				by Raven
				Just wondering why you went with 205/60/16. They seem to be the same price as 205/55/16 but only have a T speed rating. Also they are over 3% larger.
				Re:  (northvibe)
				Posted: Wed Mar 12, 2008 12:54 pm
				by Digger
				Softer ride is one reason and I was told they would wear longer than the 55s.   I drive for MPG mostly so do not need the high speed rating.  That is not to say I drive like a granny.  I do like to have fun...Just not as much these days.  I spend most of my drive dodging pot holes rather than racing..... Life in Ohio
				Re:  (Digger)
				Posted: Wed Mar 12, 2008 8:52 pm
				by Raven
				A softer ride is a good thing. The roads around here look like a mine field too. When you calculate your mileage on the new tires don't forget the speedometer error.
				Posted: Thu Mar 13, 2008 3:29 am
				by lovemyraffe
				When I bought new tires just after I got the Vibe (almost 1 year ago), I too opted for the 205/60/16.  The smoother ride is amazing, plus I noticed that my speedometer seems to be more accurate that it was on the stocks.  I only got 35k on the stock Conti's.
				Re:  (lovemyraffe)
				Posted: Thu Mar 13, 2008 8:28 am
				by Digger
				With the new tires, the speedO is still 1-2 MPH under what the GPS said I was going with the stock tires.  Also it was 14.1 mile to the place I got the tires  and  13.6 mile home.  So I will put less miles on my speedo than I actually drive    Work is now .5 mile closer also.  So that is at least a mile a day saved.  not sure which is correct.  stock tire or the 60's.   I would then guess my MPG also would inc. since every rotation of the tire is farther than it used to be,
