Bad PCM
Posted: Tue Mar 11, 2008 6:01 am
by nygiantzz1
It wasn't enough to have my wife's G5 in the shop (contaminated gas). I got a CEL on my Vibe over the weekend and it started shifting a little hard. I went to the dealer yesterday to get an estimate on the G5 and made an appointment for the Vibe. It is now fixed, the PCM had to be replaced and programmed. The dealer said the PCM was sending bad info to the pressure switch in the tranny. Thank God it's under warranty. I can pick it up after work tonight.
Posted: Tue Mar 11, 2008 7:05 am
by northvibe
ahh nice! good thing is though, the vibe should rarely have a issue if you maintain it mine has 73k miles with not 1 issue
Re: (northvibe)
Posted: Tue Mar 11, 2008 11:13 am
by BlueCrush
Quote, originally posted by northvibe »ahh nice! good thing is though, the vibe should rarely have a issue if you maintain it mine had 73k miles with not 1 issue Fixed it for you.
Posted: Wed Mar 12, 2008 4:24 am
by nygiantzz1
I got the work order from the dealer today. CEL code was P2716-Pressure Control Solenoid Operation Out of Range. It then refers to Bulletin #PIP4154 - Replace PCM. The PCM was replaced and reflashed. The car is running great. I just wanted to post this in case anyone else pulls the same code on the their Vibe.
Re: (nygiantzz1)
Posted: Thu Mar 13, 2008 3:04 am
by lovemyraffe
I know I've posted this somewhere on here before, but the PCM going bad is kinda a known problem. Not many people here have experienced it, but at the ATRA (Automatic Transmission Rebuilders Association) expo in Vegas last fall, my father-in-law sat in a conference that they discussed that problem in the Trix and Rola. Since we have the same drivetrain, there is a good chance it will happen to us too.
Re: (lovemyraffe)
Posted: Thu Mar 13, 2008 9:57 am
by mjbsb69
Quote, originally posted by lovemyraffe »I know I've posted this somewhere on here before, but the PCM going bad is kinda a known problem. Not many people here have experienced it, but at the ATRA (Automatic Transmission Rebuilders Association) expo in Vegas last fall, my father-in-law sat in a conference that they discussed that problem in the Trix and Rola. Since we have the same drivetrain, there is a good chance it will happen to us too.PCM problem of today will be like the CAT problem of 03/04....hopefully not.
Posted: Thu Mar 13, 2008 10:22 am
by northvibe
hahah thanks brain.yeah pcm's and ecu's dont tend to go bad often...hopefully this isnt like the cat problem :s then that may call for a recall on that part, there would be many anger vibers
Re: Bad PCM (nygiantzz1)
Posted: Wed Apr 23, 2008 10:57 pm
by Jon6873
My 06 with 24k miles just got its PCM replaced. CEL came on and trans shifted very hard. Turn off engine and back on the CEL still on but trans shifting normal.I have a K&N drop in, so I put back the original and the CEL went away. Put back in the K&N but after a week, problem came back. Put in original again and light went away and kept oringinal in there. A week later, same problem.Took it to the delear and they replaced the PCM. Code was also P2716.Now everything is ok, but just wierd that the air filter will cause the CEL to go on and off like that.
Posted: Wed Apr 23, 2008 11:12 pm
by northvibe
you should try a dryflow one next time, mmmm forgot who makes them, Bluecrush had one. I think its foam instead of a oiled filter. Some oiled filters if over oiled can dirty the MAF and cause issue like that. Not everyone has those issues but it comes up every once in a while.
