Cell antenna
Posted: Sat Mar 08, 2008 11:36 am
by Digger
I just got a new cell antenna. I hope it helps. I have been dropping a lot of calls with my new phone. Where do you all think it should go. Left side of top break light or the small side window. ( If it does not help it will come off. here is the type I got
http://cgi.ebay.com/CELL-PHONE...wItemI also picked up a badboy horn
Re: Cell antenna (Digger)
Posted: Sat Mar 08, 2008 11:52 am
by waveresponder
Quote, originally posted by Digger »I just got a new cell antenna. I hope it helps. I have been dropping a lot of calls with my new phone. Where do you all think it should go. Left side of top break light or the small side window. ( If it does not help it will come off. [/url]I also picked up a badboy horn i mounted a through the glass scanner antenna on the drivers side rear small side window....usually the best place to mount is the highest point on the vehicle and away from other antennas....i also chose this point so the cable wouldnt be in the way hangin down....and so i wouldn have to worry about opening and closing the hatch/liftglass..also I can keep an eye on it in case something hits it or becomes loose...
