Engine will not go above 3k RPM. Please Help!
Posted: Sun Mar 02, 2008 3:47 am
by WagonMafia
I know I've seen someone around here have the same problem but, I cant seem to find the thread. Somebody please help. I started the vibe up today and it didnt turn over the first time. When it finally started the rpm's went to the normal 1.5K when could and the dropped to about .2k. So I let it warm up and, I started to drive and I hit about 3k and it just started putting till I shifted. So if anybody can help me I would really appreciate it. Thanks
Re: Engine will not go above 3k RPM. Please Help! (WagonMafia)
Posted: Sun Mar 02, 2008 3:59 am
by BlueCrush
Your MAF sensor may be shot. Did you to anything recently in the engine bay?
by DiveNut
Your car is in "limp mode". It does that to save your engine when it "thinks" something is wrong. Could try re-setting your ECU, disconnect the battery for a few minutes. Re-start it and let it idle for about 15 minutes. You throwing a CEL? (Check Engine Light)Hope that helps,As "Blue Crush" noted, a bad MAF will do that too.
Re: Engine will not go above 3k RPM. Please Help! (DiveNut)
Posted: Sun Mar 02, 2008 4:50 am
by WagonMafia
Thanks I took it to Autozone and they said the same thing
Posted: Sun Mar 02, 2008 5:27 am
Quote, originally posted by WagonMafia »Thanks I took it to Autozone and they said the same thingWhich same thing?
Re: Engine will not go above 3k RPM. Please Help! (ragingfish)
Posted: Sun Mar 02, 2008 8:56 pm
by Sublimewind
Quote, originally posted by ragingfish »Which same thing? MAF, i'm sure..
Re: Engine will not go above 3k RPM. Please Help! (Sublimewind)
Posted: Sun Mar 02, 2008 10:47 pm
by WagonMafia
It's the MAF sensor so I ordered it 220 bucks later. I'm getting the clutch and flywheel put in today so hopefully the sensor comes in sometime this week. Thanks for all your help guys, thats why I love this place.
Posted: Mon Mar 03, 2008 12:26 am
by jake75
For the mechanically challenged - what does MAF mean?
Re: Engine will not go above 3k RPM. Please Help! (jake75)
Posted: Mon Mar 03, 2008 12:32 am
by WagonMafia
Mass Air Flow Sensor
Posted: Mon Mar 03, 2008 11:50 am
by DiveNut
Quote, originally posted by WagonMafia »It's the MAF sensor so I ordered it 220 bucks later. I'm getting the clutch and flywheel put in today so hopefully the sensor comes in sometime this week. Thanks for all your help guys, thats why I love this place.Glad you got it sorted out WagonMafia
