The REAL way to restore headlights.
Posted: Fri Feb 29, 2008 12:29 pm
by ProtonXX
I TRIED THE HEADLIGHT RESTORE KITS & THEY ARE GARBAGE. THE RUINED MY LIGHTS & MADE THEM WORST.Then I realized I can use clear coat paint.Step 1: Sand the lense down with some fine sand paper until you can get all the cracks and crap off the bulb.Step 2: Clean the headlight CaseStep 3: Spray Clear Coat Spray PaintStep 4: ????Step 5: Profit!
Re: The REAL way to restore headlights. (ProtonXX)
Posted: Mon Mar 03, 2008 12:05 am
by Whelan
I've never used clearcoat on lamps. The main concern being the heat generated. If it is not the proper type it can eventually look like rippled sand lines on the beach. Either that or it will haze faster if it is not cared for properly. Now that they are clear coated, you will want to be sure to NOT use windex on them or other plastic cleaners. Your best bet is a wax or polish since you have essentially painted them.I agree with the start with a harsher wet sanding like a 1000 and work to a 2000. But then I go for the Meguiar's PlastX and give it a few good run overs with the machine. Does wonders for the clarity.
Re: The REAL way to restore headlights. (Whelan)
Posted: Mon Mar 03, 2008 3:44 pm
by ProtonXX
Ill post an update a year later to see how they hold up lol. So far they look great.
Posted: Mon Mar 03, 2008 3:45 pm
by ProtonXX
After
Posted: Tue Mar 04, 2008 2:12 am
by Whelan
Looks good, just remember since you clearcoated, you should use wax instead of plastic cleaner on the lamps now. Here are results doing what I did for headlight restore. Not my job, but a good how-to.http://meguiarsonline.com/foru...20994
Posted: Tue Mar 04, 2008 9:04 am
by lovemyraffe
Looks great!
Posted: Sat Jun 07, 2008 1:21 am
by LOUROK
good idea. I have to try that. Anyone has before and after pictures?
