Does anyone have a diagram of a transmission for a 2005 vibe 5spd
Posted: Fri Feb 15, 2008 11:03 am
by bnjboyer
I have a 2005 vibe with 150k on it. I have been teaching my 16 year old son to drive and he has been a bit hard on the transmission. I recently had transmission problems being unable to shift gears and it was making a horrible noise. I removed the transmission and took it apart and found that the bearing on the main shaft was in peices due to the plastic cage inside the bearing races broke into chunks.... I replaced the bearing and cleaned everything up, but also had two other small bearings come out while taking it apart. I assume they are for the shifter forks but am not entirely sure where they go. I could probably figure it out, but I thought I would check on the off chance that someone out there would have a diagram of the transmission the could post for me. Help Please!!
Re: Does anyone have a diagram of a transmission for a 2005 vibe 5spd (bnjboyer)
Posted: Fri Feb 15, 2008 11:48 am
by prathman
I haven't checked the transmission section, but I believe thatmatrixowners.com still has the repair manual available on their site for download. The transmission should be identical in the Vibe.Hope you get it all back together and working right. You didn't happen to take pictures of the removal and disassembly did you? I think it'd make a great addition to some of the DIY repairs on this site.
Re: Does anyone have a diagram of a transmission for a 2005 vibe 5spd (prathman)
Posted: Fri Feb 15, 2008 1:23 pm
by bnjboyer
Thanksyou were right the site did have a manual and it has answered my problem
Posted: Fri Feb 15, 2008 1:24 pm
by bnjboyer
Sorry I didn't take any pictures of any of it.
