How To: Rear Wiper Replacement
Posted: Sun Feb 10, 2008 9:39 am
by pmarte
Clearly one can see that this blade needs replacementI used Toyota part #85214-12310Pull the wiper arm away from the car and rotate the blade outwardPull the blade assembly to the left. The blade is held by tension.To get the rubber wiper out, carefully bend it about 1.5 inches from the end until it clears the retainerThe rubber is now free to slide outThere are two 'backbones' that need to be re-used with the new rubber bladeThe replacement has grooves on each side to receive the 'backbones'Slide the rubber blade back into assemblyGently bend it to get it back in. Take care not to tweak the backbonesHere the wiper is snapped back onto the armMy index finger points to the tensioner/detent that holds the wiper in position. Give it a little push to assist the reassemblyAll done!
Posted: Sun Feb 10, 2008 9:51 am
by WaveAction
good write up, but you shoulda put it in the "tech how-to and do it yourself" thread..but one of the mods will move it, just saying for future posts. i never really knew how to change it, i figured you'd change the whole thing and not just the rubber blade it self
Re: (WaveAction)
Posted: Sun Feb 10, 2008 9:55 am
by pmarte
I put it here to check out the post and do some editing, I will move it to How To soon
Posted: Tue Feb 12, 2008 4:20 am
by Sublimewind
Hmmm... you found the proper sized replacement insert... I had to buy one double the length and cut it..
Posted: Tue Feb 12, 2008 4:51 am
by zionzr2
Posted: Fri Apr 18, 2008 9:17 am
by Magus_Taliesin
Just changed entire assembly, got the part online for $15.00 and took about 30sec to change.
Re: (Magus_Taliesin)
Posted: Fri Apr 18, 2008 11:08 am
by Raven
The rubber insert is about $3.00 at a Toyota dealer and takes 10 minutes to change.
Re: (Raven)
Posted: Fri Apr 18, 2008 10:27 pm
by zionzr2
Quote, originally posted by Raven »The rubber insert is about $3.00 at a Toyota dealer and takes 10 minutes to change.It shouldnt take that long the next time. It takes me much closer to the 30 sec. when i change just the insert.It is also not necessary to revove the blade asymbly from the vehicle.
Posted: Tue Apr 29, 2008 4:17 am
by PopeyeFAFL
You guy's are genius.So following the instructions of this site, I just replace the insert of the rear wiper of my Vibe 2005.Here the breakdown (all Canadian Prices, roughly 1$ (CDN) = 1$ (US), those days).Replacement blade unit from GM dealership: 25.15$+tax = 28.39$Replacement blade unit from Toyota dealership: 10.65$+12.02$ (not in stock)Replacement insert (qty 1) from Toyota dealership: 4.20$+tax = 4.74$So I just replace the insert, took me 5 minutes, real easy, worth it.Thanks again for your knowledge.
