A Cleaner Look (Door Center Molding Delete)
Posted: Sat Feb 02, 2008 4:47 pm
by PlatinumVibe08
EDIT 02/04/08 - There are holes in the doors behind the center moldings. Oh well. I really like the cleaner look that would be achieved by removing the center moldings from the doors. It has been discussed here previously that removing the moldings would expose small holes in the door skins. Apparently, the moldings have locating pins that protrude into the holes in the doors for alignment purposes. I inquired at two different local Pontiac dealer's body shops and was told by one that they thought they were just stuck on but ultimately didn't know for sure and the other said that they were "pretty sure" that there were locating pins.Does anyone here know for a FACT that there are holes in the doors behind the moldings? Your knowledge and expertise will be greatly appreciated. Thanks,PlatinumVibe08
Re: A Cleaner Look (PlatinumVibe08)
Posted: Sat Feb 02, 2008 9:54 pm
by kevera
They are just stuck on.I had my passenger side rear door one off at one point,and no holes.
Posted: Sat Feb 02, 2008 10:06 pm
by keithvibe
it is a much cleaner look but I have seen first hand that they have protected my car doors from jacka__ that don't give a hoot.
Posted: Sat Feb 02, 2008 11:24 pm
by WaveAction
i agree, it does look alot cleaner, but as keith said, im leaving mine on for the moment from dumb people who dont care about others doors
Posted: Sun Feb 03, 2008 1:28 am
by sstress
Whoa, I like how clean that looks.... and while my real-world mind tells me that the door bumpers are absolutely necessary to protect your car from door-dings, the reality is that I park 100 miles away from other cars. This might be something I will do... thanks for the visuals!
Posted: Sun Feb 03, 2008 1:35 am
by lovemyraffe
That might be something I will have to do in the near future. As far as door dings, they are going to happen. That little molding on the door is going to get dinged too. Somewhere you will get that stupid little ding.
Posted: Sun Feb 03, 2008 1:40 am
by coldmm803
that does look good, never thought about it. what would be the method for pulling these off? are they just held on with tape/glue like vibe badging and just heat it up with a hair dryer and use fishing line to saw thru
Re: (coldmm803)
Posted: Sun Feb 03, 2008 1:44 am
by kevera
Double sided tape.Same as removing the badges.
Posted: Sun Feb 03, 2008 8:28 am
by damronjr
Might just do this.
Posted: Sun Feb 03, 2008 11:56 am
by Blanco_Diablo
NICE!!! Love it
Posted: Mon Feb 04, 2008 6:37 am
by satur9
when i got my graphics done by george. he removed his off his vibe gt. yes there was holes. he had covered his up with graphics. best bet . pull them off carefully so you dont break the clips if you have them and need to put them back.
Re: A Cleaner Look (keithvibe)
Posted: Mon Feb 04, 2008 6:58 am
by ramenboy...
Quote, originally posted by keithvibe »it is a much cleaner look but I have seen first hand that they have protected my car doors from jacka__ that don't give a hoot.or, take them off and get this instead. ummm. maybe not.
Re: A Cleaner Look (ramenboy...)
Posted: Mon Feb 04, 2008 8:10 am
by kunkstyle
Those actually wouldn't be a bad idea if they were magnetic, so a guy could take them on/off only in parking lots.
Re: A Cleaner Look (kunkstyle)
Posted: Mon Feb 04, 2008 8:11 am
by keithvibe
Quote, originally posted by kunkstyle »Those actually wouldn't be a bad idea if they were magnetic, so a guy could take them on/off only in parking lots.or steal them LOL they are magneticWe invite you to read about our amazing magnetic car door protectors, to see how easy it is to protect your car doorStep 3 Security tether: If you need to install the security tether, simply drop the ball end of the tether into your slightly opened car door and lock your car as usual. Your doordefender is now secure.90 bucks WOW.whats to say someone just doesn't cut the tether LOL
Re: A Cleaner Look (kevera)
Posted: Mon Feb 04, 2008 8:28 am
by PlatinumVibe08
Quote, originally posted by kevera »They are just stuck on.I had my passenger side rear door one off at one point,and no holes.kevera,While there may not be holes in the rear doors, there are holes in the front doors. I gently pulled the molding out from the front passenger door enough to verify at least one hole in the door skin. Fortunately, the molding stuck right back on where it will stay. PlatinumVibe08
Re: A Cleaner Look (damronjr)
Posted: Mon Feb 04, 2008 8:32 am
by PlatinumVibe08
Quote, originally posted by damronjr »Might just do this.Only if you plan to cover the holes with graphics, etc.Quote, originally posted by satur9 »when i got my graphics done by george. he removed his off his vibe gt. yes there was holes. he had covered his up with graphics. best bet . pull them off carefully so you dont break the clips if you have them and need to put them back.Thanks satur9. Yes there are holes.
Posted: Mon Feb 04, 2008 8:40 am
by kunkstyle
Quote, originally posted by keithvibe »or steal them LOL they are magneticWe invite you to read about our amazing magnetic car door protectors, to see how easy it is to protect your car doorStep 3 Security tether: If you need to install the security tether, simply drop the ball end of the tether into your slightly opened car door and lock your car as usual. Your doordefender is now secure.90 bucks WOW.whats to say someone just doesn't cut the tether LOL Hahaha! What's to say someone doesn't break the window to prove a point because they though tethering them to a closed window was a wee bit assinine?
http://www.youtube.com/watch?v=UaY4FG5oPRI
Posted: Mon Feb 04, 2008 7:46 pm
by kevera
That's odd,I remember after getting my rear door painted a few years ago,and having to bust out my 4 foot level and marker to put that trim on.I had a hell of a time making it sit straight,and actually it's off a little and I don't remember any tabs,so I will have to rip mine off again.
Posted: Fri Mar 14, 2008 6:17 am
by hskater26
i just looked at my passenger side door moldings and i have some fresh new BIG dings on them but atleast its not my actual door........now to find that turquoise color car and accidentally run my key up against it
Posted: Fri Mar 14, 2008 11:01 pm
I like the look of the one with the moldings better. removed might be :cleaner: but it also is boring. somehow the moldings make it look more pontiac, less generic wagon
Re: A Cleaner Look (joatmon)
Posted: Tue Mar 25, 2008 5:40 am
by shawnothaninja
i agree with PlatinumVibe08... I actually never even thought about the possibility to remove the moldings, but i prefer them on.
Posted: Tue Mar 25, 2008 7:32 pm
by ToolGuy
Install a side marker light in the hole...
Re: A Cleaner Look (ToolGuy)
Posted: Wed Mar 26, 2008 1:58 am
by shawnothaninja
hmmm, that's an idea..
