My High Beams Suck !!!!
Posted: Fri Feb 01, 2008 7:37 am
by MountainMax
I have stock headllight bulbs and the low beams are great, especially with the fog lights on, however the high beams SUCK ! can i fix this by upgrading just the bulbs? has anyone had any experience in this? I was also curious if the stock wiring would handle larger wattage lights.
Re: My High Beams Suck !!!! (MountainMax)
Posted: Fri Feb 01, 2008 8:00 am
by Raven
You could try aiming the headlights a little higher. Both my '04 and '06 were aimed too low from the factory. These would do wonders too.
http://store.candlepower.com/bconibr90ulh2.html
Posted: Fri Feb 01, 2008 8:08 am
by keithvibe
try not to upgrade the wattage... you may overload the wiring harness and melt your wires or headlight housing.You can try what raven suggested and adjust your bulbs a bit. But honestly about the only true cure would be to upgrade to HIDs to the tune of about 250-300bucks
Re: My High Beams Suck !!!! (keithvibe)
Posted: Fri Feb 01, 2008 9:40 am
by Raven
I don't know if you were referring to the bulbs I suggested but they are stock wattage.
Posted: Fri Feb 01, 2008 11:10 pm
by keithvibe
keep in mind that your fog lights also go off when you turn on your highbeams unless you did the foglight/headlight modhttp://matrixowners.com/index.php?showtopic=31171
Posted: Fri Jun 27, 2008 7:09 am
by MountainMax
the fog lights only point very low anyhow, and the problem is at distance, they just don't spot enough for me, how do the new 09's compare for stock lighting?
Posted: Fri Jun 27, 2008 12:26 pm
by WD0AFQ
Silverstars work for me. One went out after 12 months though. You can buy a harness for 30 bux and use the relays for the higher wattage bulbs, but they are not legal, just real bright. Don't ask how I know.Dan
Re: (WD0AFQ)
Posted: Fri Jun 27, 2008 12:41 pm
by kunkstyle
Quote, originally posted by MountainMax »the fog lights only point very low anyhow, and the problem is at distance, they just don't spot enough for me, Isn't that kind of the point of them? To aim low. In fog.
Posted: Fri Jun 27, 2008 12:58 pm
by WaveAction
my stock highbeams are perfectly fine, brighter then the low beams and pretty much twice as far
