Strut Bar Install
Posted: Mon Jan 28, 2008 6:07 am
by B4snake
I was just wondering about this before I actually go and buy one.. How do you go about installing a Strut Bar? Is it difficult and what tools are required?
Re: Strut Bar Install (B4snake)
Posted: Mon Jan 28, 2008 6:09 am
by piecuch1
Mine was easy (unbolt, install, rebolt). Of course I did mine the same time I lowered it, so everything was taken apart already. But it isn't too involved.
Posted: Mon Jan 28, 2008 6:11 am
by kevera
I will take you 10 minutes to install.It's really straight forward.Park on a level surface,remove the 3 strut mount nuts(14mm) on either side,remove the top mounting plates,place the strut bar on,put all 6 nuts back on,and voila.
Re: Strut Bar Install (kevera)
Posted: Mon Jan 28, 2008 11:12 am
by ramenboy...
Quote, originally posted by kevera »...Park on a level surface,remove the 3 strut mount nuts(14mm) on either side,remove the top mounting plates,place the strut bar on,put all 6 nuts back on,and voila. hey kevi plan on doing this too before july. do you replace the mounting brackets? or do the ends of the strut bar (strut tower brace?) replace them?
