does anyone have greddy exhaust for the base model?
Posted: Thu Jan 24, 2008 6:32 am
by kylethakillah
I have herd several different things about it not fitting the base model but i want to know for sure before I rule it out.I basically want to know if it fit without fabrication.thanks, Kyle
Re: does anyone have greddy exhaust for the base model? (kylethakillah)
Posted: Thu Jan 24, 2008 6:56 am
by ajflan
Nope. The exhaust on the gt and base are different.
Posted: Thu Jan 24, 2008 6:58 am
by kylethakillah
thank you for helping me out man im not only new to the vibe but im new to cars in general.. haha its pretty badwhat exhaust would you recomend?
Posted: Thu Jan 24, 2008 6:59 am
by kylethakillah
ok nvr mind i read the other post thanks
by ajflan
Magnaflow makes the only true catback system for our cars. Everything else is only axle-back. For a cat-back, I would recomend Magnaflow.
Re: (ajflan)
Posted: Thu Jan 24, 2008 7:07 am
by kylethakillah
Ive actually herd a lot about magnaflow.. I'm gonna do a little more research but I'm thinking thats the way to go.thanks again
Posted: Thu Jan 24, 2008 8:46 am
by kylethakillah
the magnaflow is close to 600$ and the last time i checked the Borla was on sale for close to 300$do you think the magnaflow is worth the extra 300$?
Posted: Fri Jan 25, 2008 12:51 am
by DA1ANDONLY
if you remove the resinator car sounds so much better and it gives it a nice tone i did it to my car
Re: (kylethakillah)
Posted: Fri Jan 25, 2008 1:12 am
by Petrucci914
You can get the Magnaflow for $300-400. Check out neverenoughauto.com
Re: (kylethakillah)
Posted: Fri Jan 25, 2008 1:13 am
by ramenboy...
the borla exhaust was recently discontinued. you might be able to find one for less than $300. but the the key word here is 'find.'good luck!
Posted: Fri Jan 25, 2008 1:30 am
by drunkenmaxx
don't be afraid to go custom either man. i got my custom exhaust done for less than $400 total. (see my signiature)
Posted: Fri Jan 25, 2008 1:31 am
by ajflan
Good point, custom is a great way to go. Also, remember that Borla is only an axle-back system.
Re: (Petrucci914)
Posted: Fri Jan 25, 2008 1:39 am
by Herb
Quote, originally posted by Petrucci914 »You can get the Magnaflow for $300-400. Check out neverenoughauto.comI'm seeing $390 listed from themhttp://neverenoughauto.com/ind...=1687Also free shipping in US
Posted: Fri Jan 25, 2008 2:10 am
by drunkenmaxx
one must also note that this guy (like me) probably won't have the savvy to install the system himself, which will cost an additional amount.
Re: (drunkenmaxx)
Posted: Fri Jan 25, 2008 2:28 am
by Herb
Quote, originally posted by drunkenmaxx »one must also note that this guy (like me) probably won't have the savvy to install the system himself, which will cost an additional amount.I don't think it was that bad, though I did mess up up the cutting part by just a little bit.http://forums.genvibe.com/zerothread?id=29385Also I was missing a hanger from running over a rubber wheel chock a few years back didn't help the alignment. However, once I got the replacement hanger I took it to a shop to get it welded so I wouldn't have to worry about the clamp. The weld job was $50 and the guy at the shop helped me line things up which didn't take much.I think it's a good weekend afternoon project with a buddy.
Posted: Thu Jan 31, 2008 9:09 pm
by kylethakillah
thank you guys for helping me out.. your right most of the stuff I cant even begin to install my self. But luckily The guy at our local auto shop does lol
Posted: Thu Jan 31, 2008 11:13 pm
by WaveAction
i thought someone here had the Greddy exhaust? or atleast the muffler section of ithttp://forums.genvibe.com/zerothread?id=31511
Re: (WaveAction)
Posted: Thu Jan 31, 2008 11:51 pm
by WagonMafia
Yea I have the Greddy exhaust but it's just the axle-back kit but thats all they make. I have a GT though, if Kyle wants the greddy exhaust I would go with the Greddy Dynamic Tune Kit it has Two outlets from the muffler and you can plug one up to give it a higher or lower exhaust note deppending on your preferance. If thats what you would like to go with check out the greddy website, and find the outlet section. There only a 100 bucks because there discontinuing them, so i would jump on it quick. Then with your K&N CAI, PPE Headers, Magnaflow Hi-Flow Cat, and a resonater delete your vibe is gonna sound nice. If they dont have any more though just go with a Invidia, Tanabe, Skunk2, or Greddy Evo 2 if thats the way you wanna go for the import exhausts, these are for the 2zzge though. They'll fit but all you have to do is change the flange
Posted: Thu Jan 31, 2008 11:58 pm
by kylethakillah
where can you find a flange? and how hard is it to change the it?
Re: (kylethakillah)
Posted: Fri Feb 01, 2008 12:10 am
by WagonMafia
You could probably just take it to a shop and by the flange there, like midas or some local shop.
Posted: Fri Feb 01, 2008 12:46 am
by kylethakillah
the only problem is I live in a very very redneck town in the middle of nowhere so I would have to order it from somewhere or go at least 50-60 miles out of the way to get one
Re: (kylethakillah)
Posted: Fri Feb 01, 2008 3:35 am
by WagonMafia
You can use your stock exhaust and weld it to the new one. Are there any local shops that would be able to do it for you. I say go custom it would be the same as buying the kit, and if you have enough confidence do it yourself. All you need is a tig welder, a sawsall, and the neccesary tools to install the exhaust.
Posted: Fri Feb 01, 2008 11:53 am
by kylethakillah
im really thinking about that. just cutting the flange off the new pipe and replacing it with the one from the original pipe.
Re: (kylethakillah)
Posted: Sun Feb 03, 2008 10:50 pm
by DA1ANDONLY
sorry wagonmafia but those import exhausts are not just for 2zzge..evo2 exhaust are usually for turbo cars..that guy can pretty much get any exhaust..but if he does want it to sound nice..he might have to go custom..by the way wagonmafia what greddy exhaust do you have?
Re: (DA1ANDONLY)
Posted: Mon Feb 04, 2008 12:27 am
by WagonMafia
I have the Evo2, and there not usually for turbo cars but they do have kits for turbo cars to. Your probably thinking of the EvoTT those kits are for Turbo cars only because they have larger piping to optimize performance in its boosted form. I told kyle that those kits i mentioned were for the 2zzge not the 1zzge. I know they make them for other cars to.
Re: (kylethakillah)
Posted: Mon Feb 04, 2008 12:49 am
by DA1ANDONLY
well look around online.. evo2 were meant for turbo cars...thats why when i was listening to ur exhaust vids..i notice your exhaust was loud towards the end...gurantee if you get a new exhasut ur car would sound so much better...not saying nothing wrong with ur exhaust. but evo2 not meant for cars that do not have turbos.
Re: (DA1ANDONLY)
Posted: Mon Feb 04, 2008 2:02 am
by WagonMafia
My exhaust was loud at the end of the gear because of lift, not because my exhaust was meant for turbo'd cars. Go take a look at the greddy website.
Re: (kylethakillah)
Posted: Mon Feb 04, 2008 2:29 am
by DA1ANDONLY
i know its the lift that makes it loud.. what im trying to say is that ur exhaust gets loud when is at high rpm...i bet when ur driving normal it does not sound loud like it does at the end..when u have a constant sound from begining to end thats a normal exhaust..ur exhaust sounds loud when is at high rpms and when lift kicks.
Re: (DA1ANDONLY)
Posted: Mon Feb 04, 2008 2:57 am
by WagonMafia
It does sound the same through 1k to 6k then lift kicks in. Thats the only time its louder. Plus that video sucked cuz i used a phone, in person its a lot different.
Re: (WagonMafia)
Posted: Tue Feb 05, 2008 2:35 am
by kylethakillah
so do you think it would work on the base if I replaced the flange? oh and does ne one know if the hangers on the base and gt are the same?
Re: (kylethakillah)
Posted: Wed Feb 06, 2008 3:18 am
by DA1ANDONLY
that is not a phone you used because it would not sound like that it would sound ugly if u used the phone... well see what you can do man i really want to hear that exhaust..i dont know if i want to keep my borla or not
Re: (DA1ANDONLY)
Posted: Wed Feb 06, 2008 3:42 am
by kylethakillah
whats wrong with your borla? does it sound good?
Re: (DA1ANDONLY)
Posted: Wed Feb 06, 2008 10:11 pm
by DA1ANDONLY
borla sounds lovely...but im always willing to try different things on my car ..but i want to hear how a greddy sounds im waiting on wagonmafia to get a new video so i can listen to it.
Posted: Thu Feb 07, 2008 9:15 pm
by kylethakillah
has ne one herd about the skunk2? any sound clips?
Re: (DA1ANDONLY)
Posted: Tue Feb 12, 2008 9:25 am
by WagonMafia
Here you sorry it took so long I've been real busy with work.
Posted: Tue Feb 12, 2008 9:05 pm
by kylethakillah
its ok. I finally got my intake on so exhaust comes next =]still trying to decide
