zero camber edit adjusting toe
Posted: Thu Mar 27, 2003 8:51 am
by satur9
the srt-4 is set at 0 camber supposedly for maxium straight line traction. 1.5 and zero is not that big a difference and cornering should not be affected that bad, im going to try it! but what do you guys think?(i also dont like the way tires look tilted in)
Re: zero camber edit adjusting toe (satur9)
Posted: Wed May 27, 2009 6:55 am
by satur9
wow blast from the past. i was doing a search didnt find anything about toe. i got megan recing coilovers on a few weeks back. and after all these years i got zero camber(pillowballs). anyway how do you adjust toe.theres a small steering wheel shake above 70 mph. and if i take it to aligment shop i want camber left at zero(or could that be the problem.3 sets of springs no aligment ever no problems 1 set of coilovers. problem. anyway could toe be off causing wobble. if only camber is adjustable . i could tweak it a bit my self see what happens. dont wanna pay for nothing ya know.
Posted: Wed May 27, 2009 7:11 am
by keithvibe
Quote, originally posted by satur9 »wow blast from the past. i was doing a search didnt find anything about toe. i got megan recing coilovers on a few weeks back. and after all these years i got zero camber(pillowballs). anyway how do you adjust toe.theres a small steering wheel shake above 70 mph. and if i take it to aligment shop i want camber left at zero(or could that be the problem.3 sets of springs no aligment ever no problems 1 set of coilovers. problem. anyway could toe be off causing wobble. if only camber is adjustable . i could tweak it a bit my self see what happens. dont wanna pay for nothing ya know.camber can be left at zero and just adjust the toe. shouldn't be an issue for a shopcamber shouldn't cause your wobbleDid you get it aligned after the coil install?If anything i would say you lost a weight on one of your rims and it's off balance now. From your recent trip to the shop maybe
Re: zero camber edit adjusting toe (keithvibe)
Posted: Wed May 27, 2009 8:26 am
by satur9
weights first thing checked.it was shakey before that.
Posted: Wed May 27, 2009 1:32 pm
by Sublimewind
If you had a toe issue, you would be cupping the tires... inside or outside edge.. Toe is adjusted via the tie rod end.. spun in for - toe, spun out for +... Most cars have a slight toe in, helps with stability, and one of the reasons you need to rotate.. A little camber isn't bad, but a lot can.. we've most all seen it.. dumped ford rangers are good for wikkid camber angle.. Old Vdubs too.. lol... I wouldn't trust my ride to my alignment skills, much less my life... take it in..
Re: (Sublimewind)
Posted: Fri May 29, 2009 7:35 am
by satur9
i doubt the coilovers have been on long enough to notice tire wear. but i got an aligment done and its all good now.
Posted: Fri May 29, 2009 9:32 am
by Sublimewind
Sweet... Coilovers.. tell me more..
