Plastic or metal on dash
Posted: Fri Jan 11, 2008 9:20 am
by asburydan
Would I be right in assuming the gun-metal gray looking surrounds on the dash are good plastic vs. metal? They sound like plastic when I tap on them, but they look like metal that could be waxed like car exterior.Thanks.
Posted: Fri Jan 11, 2008 9:35 am
by lovemyraffe
Pretty sure they are plastic. When I say "pretty sure" I mean 102%
Re: (lovemyraffe)
Posted: Fri Jan 11, 2008 9:50 am
by asburydan
Thanks. I thought so too.Dan
Posted: Sat Jan 12, 2008 12:06 am
by Sublimewind
This may sound funny, but when I question things like this, i try and to the "tooth" test... if you can get a tooth on it... it will imideatly tell you what matieral it is... metal plastic or glass...
Re: (Sublimewind)
Posted: Sat Jan 12, 2008 1:13 am
by lovemyraffe
You should chew on some aluminum foil. Does great with fillings.
