Need Parts Help
Posted: Wed Jan 09, 2008 9:32 am
by thoughtdegree
I need help figuring out a part number for this push-in-retainer clip. I think that is what it is called. If you can see the attached picture you will notice that the pieces on the back are broken.
Re: Need Parts Help (thoughtdegree)
Posted: Wed Jan 09, 2008 9:34 am
by thoughtdegree
These were located on the plastic shroud that is under the car right in front of the oil pan area.
Posted: Wed Jan 09, 2008 11:30 am
by 4azdmunky
I don't know the exact part number, however Checker and Autozone have similar ones in their bolts/screws area. They are marked as plastic rivets (or something like that) and are also marked as GM. They are not exactly the same, but they work the same and fit. I ended up replacing all of mine over time with them and never had an issue.
Posted: Fri Apr 18, 2008 6:37 pm
by joejoev
I think the GM part # is 88970767.I had to replace a few of those myself and ended up using OEM front grille retainer clips (part #94853733) since I had an extra bag of them. They don't hold as tight as the original retainers, but they do the job.
