Air Box
Posted: Wed Mar 26, 2003 2:51 am
by rubberman
Does anybody know what the white plastic tube inside the airbox lid does. I took my plastic tube that runs from the air box out i am going to replace it with a larger piece of tubing or with a large hose to allow more air into the air box.
Re: Air Box (rubberman)
Posted: Wed Mar 26, 2003 2:59 am
by NovaResource
Basically it just helps straighten out the air flow path.
Re: Air Box (NovaResource)
Posted: Wed Mar 26, 2003 3:02 am
by rubberman
Thanks so if i take it out it will be no big problem
Posted: Wed Mar 26, 2003 3:07 am
by NovaResource
I woudn't because it could cause turbulance and decrease flow.
Posted: Wed Mar 26, 2003 3:20 am
by rubberman
thanks for the info
Posted: Thu Mar 27, 2003 9:13 am
by MadBill
I think turbulence is the issue, just as NovaResource says.I used a GM Tech II scan tool on my base Vibe, and the "long term fuel correction" values changed from plus 2-3% to minus ~ 8% (indicating that the MAF sensor was no longer giving accurate data) when I pulled out the tube. The bell shape should help air flow, but the grid (which apparently is there as an additional flow straighener, to ensure accurate readings from the Mass Air Flow Sensor) seems to hurt it by ~15%. I'd like to cut out the grid and see what happens, but first I'll have to see if the tube is sold separately and at what price, in case the test is a flop.Makes you wonder if the sensor readings are always accurate with a CAI, since I don't think any of them have flow straighteners. Maybe that's part of the performance gain: They trick the MAF sensor and alter the fuel mixture...
Re: Air Box (MadBill)
Posted: Thu Mar 27, 2003 6:56 pm
by rubberman
Thanks for the info Bill.Iremoved the intake tube i think i am going to do what the one guy did with his car and make a ram air tube for it just till i get the cash for a k&n typoon kit
