Volume gone!
Posted: Wed Jan 02, 2008 12:45 am
by jcleugers
Volume gone! Audio system in 03 GT with 6cd works etc., lights, but no volume at all. Chec ked all fuses. Tried new aftermarket: still no volume.Help!!!!
Re: Volume gone! (jcleugers)
Posted: Wed Jan 02, 2008 1:12 am
by Sublimewind
Blown or shorted speakers...
Posted: Wed Jan 02, 2008 1:13 am
by Sublimewind
Welcome BTW....Do you have either of the factory amplified systems?? I forgot to ask...
Posted: Wed Jan 02, 2008 1:42 am
by Sublimewind
Just to add, blown speakers (usually open) cause no problems, BUT shorted speakers (wires usually) usually take out the output IC in the HU.... not good...
Re: (Sublimewind)
Posted: Wed Jan 02, 2008 2:04 am
by jcleugers
It is the 200 watt premium audio system that came with the moon and tunes package. Would all of the spkrs blow at the same time? It was after my wife had the battery replaced.
Posted: Wed Jan 02, 2008 2:19 am
by Sublimewind
Hmmm, that's odd, i'm not familar with either of the preium packages, so hopefully someone else will come in with some info... What I outlined may not be the case at all now...
Posted: Wed Jan 02, 2008 5:24 am
Quote, originally posted by jcleugers »Checked all fuses.including the 25A "AMP" fuse in the fuse block under the hood?
Posted: Wed Jan 02, 2008 5:42 am
by jcleugers
yes
Re: (jcleugers)
Posted: Wed Jan 02, 2008 5:49 am
by piecuch1
Do any work recently that could have pinched a speaker wire and it is shorting out? I did this once when installing a set of new speakers in the back of my old truck. I ran the wires under the carpet by the doors and when I put the trim piece back on it caught the wire and pulled enough of the shielding back where it was shorting out on the metal of the body. Just a thought.
Posted: Wed Jan 02, 2008 10:06 am
by jcleugers
nope. Wish it was that simple.
