O gauge amp wire good place IN THE FIRE WALL
Posted: Thu Dec 27, 2007 11:19 am
by aztek02
GETTING A AMP IN THE VIBE LOOKING for a good place for the amp wire to go in from the batt to the amp do i have to drill or if somone has a good pic i can see how you did it THANKS
Re: O gauge amp wire good place IN THE FIRE WALL (aztek02)
Posted: Thu Dec 27, 2007 9:15 pm
by flywithabowtie
Where are you going to locate the amp? If you are going to put it near the front of the car, you can look for the rubber grommet in your firewall. I installed my amp in the back and ran the wire under the car and zip tied it to the brake lines and up thru the rubber grommet in the spare tire well.
Posted: Thu Dec 27, 2007 10:53 pm
by Sublimewind
Hi and Welcome to GenVibe...!!!If you drill a hole PLEASE PLEASE use a grommit in the firwall, a PLASTIC one would be preferable over rubber, if you are in fact using 1/0g wire as it's quite heavy... What are you running that you need 1/0g wire??? I know i'm using 1/0g for my Rockford Power 1000 5ch, But i'm also shooting for the highest quality I could from the power, my install DOES NOT require 1/0g at all... I could easily get away with 4g, but my battery is also relocated in the trunk and i'm looking for un-impeeded current transfer(back to the motor and from the Alt. to the batt.)... So, what are the install plans?? (former installer here BTW)
Posted: Fri Dec 28, 2007 5:39 am
by GotYourVibes
The install of the amp that you are talking about is goin into my vibe....my names Craig im new to all of this.
Posted: Fri Dec 28, 2007 8:41 am
by audiovibe
I ran my 0awg through thefirewall at the top of the dash closer to the center. Ill try to get a pic when I go to do some more work on it. Its under audiostruction at the moment.Aron
Re: (GotYourVibes)
Posted: Fri Dec 28, 2007 11:19 pm
by Sublimewind
Quote, originally posted by GotYourVibes »The install of the amp that you are talking about is goin into my vibe....my names Craig im new to all of this.Ok, I don't get it, do you have 2 different SN?? Are you the OP that started that thread?? Ok, so you are installing amps, what amps, where are you going to put them, what else are you running? If you are new to this, you might have considered asking some questions up front to get a little starting advise... Anyhoo, let's hear what you got going on.,.,,
Posted: Sat Dec 29, 2007 12:28 am
by GotYourVibes
no the aztek02 is my friend joe who is helping me do all of this he has an audio installation company and is part of a car club that we are both a part of...i have a 2003 vibe with 60,000mi. on it...we are putting the amp in the back hatch this amp is for my door speakers (kicker) we are runing 0g wire because i am adding atleast 2 additional batteries 2 more amps and 4 10" L7 SoloBaric subs and everything is kicker all the way down to the wiring...my names craig by the way im 16 years old and go to shows all the time all throughout central illinois.
Posted: Sat Dec 29, 2007 2:56 pm
by audiovibe
woot just saw your from IL as well.Aron
