03-08 wire diagram
Posted: Fri Dec 21, 2007 2:17 pm
This diagram is for 2003-2008 Pontiac Vibes onlyThere have been a few post asking for wire diagrams for the vibe, so I thought I would share the one that was printed for me. Please if you are not comfortable working on an automobiles electrical system; practice on a friends car Seriously if you're not comfortable please take your car to a professionalAudio/Mobile VideoBatteryBLUE/WHITE(+)RADIO HARNESSAccesoryGRAY(+)RADIO HARNESSGroundBROWN(-)RADIO HARNESSIlluminationGREEN(+)RADIO HARNESSDimmerWHITE/BLACK(-)RADIO HARNESSPower AntennaBLACK(+)RADIO HARNESSAmp Turn OnBLACK(+)RADIO HARNESSLF Speaker (+)PINK AT THE RADIO HARNESSLF Speaker (-)VIOLET AT THE RADIO HARNESSRF Speaker (+)LIGHT GREEN AT THE RADIO HARNESSRF Speaker (-)BLUE AT THE RADIO HARNESSLR Speaker (+)BLACKLR Speaker (-)YELLOWRR Speaker (+)REDRR Speaker (-)WHITEAmp LocationLOCATED UNDER THE FRONT PASSENGERS SEATSteering CntrlsOPTIONALSpeed CntrlOPTIONALRadio SecurityYESConvenienceHeadlights-LoRED(-)HEADLIGHT SWITCHHeadlights-HiRED/YELLOW(-)AT VEHICLE LIGHT SWITCH HARNESSLF Pk Lt BulbGREEN(+)AT FRONT LEFT PARKING LIGHTRF Pk Lt BulbGREEN(+)AT FRONT RIGHT PARKING LIGHTLR Pk Lt BulbGREEN(+)AT REAR LEFT PARKING LIGHTRR Pk Lt BulbGREEN(+)AT REAR RIGHT PARKING LIGHTAll Hazrd LightsYELLOW/BLAC(-)HAZZARD SWITCHLF Hazrd BulbGREEN/BLACK(+)AT FRONT LEFT DIRECTIONAL LIGHTRF Hazrd BulbGREEN/YELLOW(+)AT FRONT RIGHT DIRECTIONAL LIGHTLR Hazrd BulbGREEN/BLACK(+)AT REAR LEFT DIRECTIONAL LIGHTRR Hazrd BulbGREEN/YELLOW (+) AT REAR RIGHT DIRECTIONAL LIGHTWipers-LoBLUE/WHITE(+)STEERING COLUMNWipers-HiBLUE/RED(+)STEERING COLUMNParking BrakeRED/BLACK(-)AT PARKING BRAKE SWITCH HARNESSTrnk ReleaseBLUE/WHITE(-)AT THE SWITCH IN THE DRIVERS DASHControl ModulesModule 1PCM - POWERTRAIN CONTROL MODULE IS LOCATED BEHIND THE GLOVE BOXSecurityBatteryWHITE & BLACK(+)IGNITION SWITCH HARNESSIgnition 1BLACK/WHITE(+)IGNITION SWITCH HARNESSStarter 1RED(+)IGNITION SWITCH HARNESSAll Door TriggerRED/YELLOW(-)DRIVERS KICK PANELNote #1Domelight SuperRED/WHITE(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXNote #2LF LatchRED/WHITE(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXRF LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXLR LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXRR LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXAlarm DisarmBLUE/YELLOW(-)@ BLU 15 PIN CONN. IN THE DR. KICKNote #3Alarm ArmGREEN(-)@ BLU 15 PIN CONN. IN THE DR. KICKNote #4Parking LightsGREEN(+)DRIVERS KICK PANELLow Crr Pk LightsGREEN/WHITE(-)AT THE TOP OF THE STEERING COLUMN Remote StartBatteryWHITE & BLACK(+)IGNITION SWITCH HARNESSIgnition 1BLACK/WHITE(+)IGNITION SWITCH HARNESSIgnition 2BLACK/YELLOW(+)IGNITION SWITCH HARNESSAccessory 1BLUE/RED(+)IGNITION SWITCH HARNESSStarter 1RED(+)IGNITION SWITCH HARNESSAnti-Theft TypePASSKEY IIIAnti-Theft DescriptAN RF SIGNAL ACTIVATED SYSTEMKey SenseBLUE/BLACK(-)IGNITION SWITCH HARNESSTachometerRED/BLUE(AC)@ THE IGNITION COILNote #5Crankshaft SensorBLACK(+)AT PCM MODULE UNDER GLOVEBOXNote #6Camshaft SensorBLACK(+)AT PCM MODULE UNDER GLOVEBOXNote #7Speed SenseVIOLET/WHITE(+)AT GAUGE CLUSTER HARNESS BEHIND DASHParking LightsGREEN(+)DRIVERS KICK PANELLow Crr. Pk LightsGREEN/WHITE(-)AT THE TOP OF THE STEERING COLUMNBrake LightsGREEN/WHITE(+)AT THE SWITCH ABOVE BRAKE PEDALReverse LightsRED/BLACK(+)PIN 11 AT THE PCM CONNECTOR 3HornGREEN/YELLOW(-)IN 12 PIN PLUG NEXT TO THE AIRBAG PLUG @ THE STEERDoor Locks/WindowsPower UnlockBLUE(-)AT BLUE 15 PIN CONNECTOR IN THE DR. KICKNote #8PowerLockBLUE/WHITE(-)AT BLUE 15 PIN CONNECTOR IN THE DR. KICKNote #9Driver Mtr UnlockRED/SILVER DOTS(REV)AT BLUE 15 PIN CONNECTOR IN THE DR. KICKDriver Mtr LockBLUE/SILVER DOTS(REV)AT BLUE 15 PIN CONNECTOR IN THE DR. KICKPas Mtr UnlockRED/SILVER DOTS(REV)AT BLUE 15 PIN CONNECTOR IN THE DR. KICKPas Mtr LockBLUE(+)AT MOTOR IN DOORLF Window UpYELLOW(REV)DRIVERS DOOR WINDOW SWITCHLF Window DnGREEN(REV)DRIVERS DOOR WINDOW SWITCHRF Window UpBLACK/RED(REV)DRIVERS KICK PANELRF Window DnBLACK/WHITE(REV)DRIVERS KICK PANELLR Window UpRED/BLUE(REV)DRIVERS KICK PANELLR Window DnBLUE(REV)DRIVERS KICK PANELRR Window UpRED/BLUE(REV)DRIVERS KICK PANELRR Window DnRED(REV)DRIVERS KICK PANELSunroof OpenGREEN OR RED(REV)SUNROOF SWITCHSunroof CloseGREEN/WHITE OR RED/BLUE(-)SUNROOF SWITCHNote #1: YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS.Note #2: PIN #3Note #3: A SINGLE PULSE DISARMS THE ALARM & UNLOCKS THE DRIVERS DR. A SECOND PULSE UNLOCKS ALL DOORSNote #4: THIS WIRE ALSO LOCKS THE DOORSNote #5: YOU CAN ALSO USE A YEL/GRN, GRY AND A WHT. THE COILS ARE LOCATED ON THE SIDE OF THE ENGINE YOU CAN ALSO USE A FUEL INJECTOR. USE THE OPPOSITE OF THE BLK/WHT YOU CAN ALSO USE A BLACK PIN 5 AT THE PCM CONNECTOR 4Note #6: PIN #27Note #7: PIN #25Note #8: IF EQUIPPED WITH FACTORY SECURITY, SEE THE ARM AND DISARM WIRESNote #9: PIN #7 & #19 - YOU MUST DIODE ISOLATE THE UNLOCK PULSE FROM THE ALARM UNIT TO AVOID FEEDBACK. SEE DOUCMENTS.This diagram is for 2009-2010 Pontiac Vibes onlyAudio/Mobile VideoBattery LIGHT BLUE (+) RADIO HARNESS Accessory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Power Antenna TAN (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE ConvenienceHeadlights-Lo GREEN (-) AT VEHICLE LIGHT SWITCHHeadlights-Hi LIGHT GREEN (-) AT VEHICLE LIGHT SWITCHLF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LAMP RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LAMP LR Pk Lt Bulb GREEN (+) AT REAR LEFT PARKING LAMP RR Pk Lt Bulb GREEN (+) AT REAR RIGHT PARKING LAMPAll Hazrd Lights TAN (-) AT VEHICLE HAZARD SWITCH LF Hazrd Bulb YELLOW (+)AT FRONT LEFT TURN LAMP RF Hazrd Bulb BLUE/RED (+) AT FRONT RIGHT TURN LAMP LR Hazrd Bulb YELLOW (+) AT REAR LEFT TURN LAMP RR Hazrd Bulb LIGHT BLUE (+) AT REAR RIGHT TURN LAMP Wipers-Lo BLACK (+)AT WIPER CONTROL SWITCH Wipers-Hi RED (+) AT WIPER CONTROL SWITCH Parking Brake TAN (-) AT VEHICLE PARKING BRAKE SWITCHSecurityBattery BLUE & RED (+) IGNITION SWITCH HARNESS Ignition 1 GREEN (+) IGNITION SWITCH HARNESS Starter 1 WHITE (+) IGNITION SWITCH HARNESS All Door Trigger GRAY (-) AT MAIN BODY ECU Note #1LF Latch VIOLE
T (-) AT MAIN BODY ECU RF Latch TAN (-) AT MAIN BODY ECU LR Latch YELLOW (-) AT MAIN BODY ECU RR Latch BLACK (-) AT MAIN BODY ECU Trunk Trigger LIGHT GREEN (-)AT MAIN BODY ECU Alarm Disarm PINK (-) AT MAIN BODY ECU Note #2Parking Lights GREEN (+) IN HARNESS IN DRIVER KICKPANEL Low Crr Pk Lights BROWN (-) AT VEHICLE LIGHT SWITCHRemote StartBattery BLUE & RED (+) IGNITION SWITCH HARNESS Ignition 1 GREEN (+) IGNITION SWITCH HARNESS Ignition 2 BROWN (+) IGNITION SWITCH HARNESS Accessory 1 GRAY (+) IGNITION SWITCH HARNESS Starter 1 WHITE (+) IGNITION SWITCH HARNESS Starter 2 BLACK (+) IGNITION SWITCH HARNESS Anti-Theft Type UNIVERSAL IMMOBILIZER Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER Key Sense BLUE (-) IGNITION SWITCH HARNESS Tachometer GRAY (AC) AT DATLINK CONNECTOR UNDER DRIVER SIDE DASH Speed Sense VIOLET (AC) AT ECM MODULE Parking Lights GREEN (+) IN HARNESS IN DRIVER KICKPANEL Low Crr. Pk Lights BROWN (-) AT VEHICLE LIGHT SWITCH Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL Reverse Lights RED (+) IN HARNESS BEHIND TRIM IN LEFT SIDE OF CARGO AREA Horn LIGHT GREEN (-) IN HARNESS AT STEERING COLUMN IMO LIGHT GREEN (DATA) AT TRANSPONDER ECU BEHIND RADIO IMI PINK (DATA) AT TRANSPONDER ECU BEHIND RADIO Rear Defrost TANDoor Locks/WindowsPower Unlock TAN (-) AT MAIN BODY ECU Power Lock VIOLET (-) AT MAIN BODY ECU Driver Mtr Unlock GREEN (REV) IN DRIVER KICKPANELDriver Mtr Lock TAN (REV) DRIVER KICKPANEL Pas Mtr Unlock GREEN (REV) IN PASSENGER KICKPANEL Pas Mtr Lock TAN (REV) IN PASSENGER KICKPANEL LF Window Up GREEN (REV) AT MASTER WINDOW CONTROL SWITCH LF Window Dn YELLOW (REV) AT MASTER WINDOW CONTROL SWITCH RF Window Up GREEN (REV) AT MASTER WINDOW CONTROL SWITCH RF Window Dn BROWN (REV) AT MASTER WINDOW CONTROL SWITCH LR Window Up RED (REV) AT MASTER WINDOW CONTROL SWITCH LR Window Dn BLUE (REV) AT MASTER WINDOW CONTROL SWITCH RR Window Up BLACK (REV) AT MASTER WINDOW CONTROL SWITCH RR Window Dn YELLOW (REV) AT MASTER WINDOW CONTROL SWITCH Sunroof Open GREEN (-) AT SUNROOF CONTROL SWITCH Sunroof Close BLUE (-) AT SUNROOF CONTROL SWITCHNote #1 TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRENote #2 A DOUBLE PULSE ON THIS WIRE WILL UNLOCK ALL DOORSPlease if you are not comfortable working on an automobiles electrical system; practice on a friends car Seriously if you’re not comfortable please take your car to a professional
