Tranny Cooler NPT Inlet/Outlet Size
Posted: Thu Dec 20, 2007 6:50 am
by Petrucci914
Hey guys,I'm getting conflicting reports on what size NPT fittings my tranny cooler should have. I was first told 1/2" but others tell me that's too big. The 1/2" NPT coolers tend to be very big and rarely come with mounting hardware so if one of the other coolers work that'd be a big plus. Thanks!
Re: Tranny Cooler NPT Inlet/Outlet Size (Petrucci914)
Posted: Thu Dec 20, 2007 8:01 am
by djb383
Check your IM.
Re: Tranny Cooler NPT Inlet/Outlet Size (djb383)
Posted: Thu Dec 20, 2007 8:18 am
by Petrucci914
Ya, I got you IM, thanks. But another person has said 1/2" fittings. But if you got a cooler with the 3/8" barbs and it worked then that works for me. 3/8" and 1/2" is very close...either way I think you could slide it on.
Posted: Thu Dec 20, 2007 8:28 am
by keithvibe
Quote, originally posted by Petrucci914 » 3/8" and 1/2" is very close...either way I think you could slide it on.Um... what world do you live in where 3/8th of and inch and 1/2 an inch are very close... they aren't close when your talking inside diam. of a hose... that's a full 1/8th of in inch difference. If you stretch the hose that much you will weaken the sides of the hose causing it to split a lot sooner than you think.My 2c... get the right size fitting or hose.
Re: Tranny Cooler NPT Inlet/Outlet Size (keithvibe)
Posted: Thu Dec 20, 2007 8:35 am
by Petrucci914
I wouldn't jam a smaller hose over a larger barb. I'd put a 1/8" larger hose over a smaller barb, though, with the right hose clamp. I just ordered one with the 3/8" barb. I think it'll work just fine. Don't worry, I'll do it right. I always play it safe.
Posted: Thu Dec 20, 2007 9:52 am
by djb383
Post a pic when you get'er done.
Posted: Fri Dec 21, 2007 2:44 am
by kevera
Sorry man,I haven't installed mine yet and another member told me that(I won't name names) it was the 1/2" size.Let me know how it works out.
Re: Tranny Cooler NPT Inlet/Outlet Size (kevera)
Posted: Fri Dec 21, 2007 2:53 am
by Petrucci914
No problem, man. It worked out better this way as it comes with all the mounting hardware. I'll let all know how it goes.
Posted: Fri Dec 21, 2007 3:39 am
by djb383
Which cooler did you get?
Posted: Fri Dec 21, 2007 3:47 am
by Petrucci914
http://www.transmissioncoolers...unt=1
Posted: Fri Dec 21, 2007 9:24 am
by djb383
Headered style............good choice.
