New Engine Installed Yay!
Posted: Sat Dec 08, 2007 1:42 am
by ProtonXX
But 2 CEL Error Codes. Boo!P1656& P0325Anyone know exactly where the Knock sensor is at on 1ZZ? Im hoping its not under the air intake manifold
Re: New Engine Installed Yay! (ProtonXX)
Posted: Sat Dec 08, 2007 3:14 am
by Raven
If you don't mind me asking, what was the total cost of replacement?Most Japanese engines are pretty sane as far as knock sensor location but I don't know where it is on a 1ZZ. On my Subaru it's right on top of the engine at the back in plain view. My GMC requires removal of the intake manifold as you mentioned. It's also in a low spot which fills with water if you wash your engine and the connector corrodes and gives a CEL.
Re: New Engine Installed Yay! (Raven)
Posted: Sat Dec 08, 2007 6:32 am
by ProtonXX
$1100 for engine$100 for water pump (just in case)$30 for thermostat i think (just in case)$15 for locktight (for torque convertor and flywheel)$100 ($35 a day for 3 days for mhobby shop bay & tool rental)$105 for broken OCV Valve (P1656 Error)$40 for antifreeze, trans fluid & Oil & Power steering fluid (we took the power steering hoses off by accident.
Posted: Sat Dec 08, 2007 7:08 am
by Raven
DIY Well done.
Posted: Sat Dec 08, 2007 7:15 am
by keithvibe
Quote, originally posted by ProtonXX »Anyone know exactly where the Knock sensor is at on 1ZZ? Im hoping its not under the air intake manifold Yes it is...
Posted: Sat Dec 08, 2007 8:15 am
by damronjr
Welcome to the DIY Vibe Engine Replacement Club! Lots of fun, huh?!? I managed to get away without any CELs when I did mine. Good luck ripping that IM off again!
Re: New Engine Installed Yay! (damronjr)
Posted: Sat Dec 08, 2007 1:03 pm
by ProtonXX
fixed. the screw was loose & I tightened it. No more CELs
Posted: Sat Dec 08, 2007 1:08 pm
by ProtonXX
fixed. the screw was loose & I tightened it. No more CELsPics are herehttp://www.clan-lone.com/forum...t=736
Posted: Sat Dec 08, 2007 1:21 pm
by Petrucci914
Why did you have to replace your engine?
Re: New Engine Installed Yay! (Petrucci914)
Posted: Sat Dec 08, 2007 1:31 pm
by damronjr
Quote, originally posted by Petrucci914 »Why did you have to replace your engine?I'm guessing it has something to do with this:http://forums.genvibe.com/zerothread?id=31207
Posted: Sun Dec 09, 2007 6:19 am
by ProtonXX
Quote, originally posted by damronjr »I'm guessing it has something to do with this:http://forums.genvibe.com/zerothread?id=31207Yep thats the old one
Posted: Sun Dec 09, 2007 6:28 am
by keithvibe
Quote, originally posted by ProtonXX »fixed. the screw was loose & I tightened it. No more CELsdid you have to take the manny off or did you get in there some how?
Re: New Engine Installed Yay! (keithvibe)
Posted: Sun Dec 09, 2007 7:16 am
by ProtonXX
Transmission stayed in. We had to unscrew the torque converter thru the starter hole & the hole on the bottom (its covered by a brake show shaped piece of plastic.). Looking back leaving the transmission in made things easier because all the extra wires and stuff sat on that side anyway.
Posted: Sun Dec 09, 2007 10:11 am
by damronjr
Quote, originally posted by ProtonXX »Transmission stayed in. We had to unscrew the torque converter thru the starter hole & the hole on the bottom (its covered by a brake show shaped piece of plastic.). Looking back leaving the transmission in made things easier because all the extra wires and stuff sat on that side anyway.I left mine in as well, but others have said it is easier to remove the whole thing. With no experience going that route, all I can say is to each his own, but to me it seems simpler to leave the tranny in.
