accessory belt tensioner job
Posted: Thu Nov 29, 2007 10:38 am
by jamesmetairie
when doing the (2003 base) accessary belt tensioner replacement job is replacing the water pump a good idea. car has about 85,000 miles.
Re: acces belt tensioner job= (jamesmetairie)
Posted: Thu Nov 29, 2007 12:57 pm
by Petrucci914
I wouldn't think that it's necessary. It's not like releasing the belt tensioner is hard, so you wouldn't really be saving yourself a headache by doing it now. I'm not even sure of anybody having a bad water pump on their vibe ever on these forums.
Re: acces belt tensioner job= (Petrucci914)
Posted: Thu Nov 29, 2007 7:49 pm
by kevera
While you have the belt off,it's a good idea to check 2 things on the tensioner.Check the pulley itself,to see if it wobbles back and forth or up and down.Then also check the hydraulic shock to see if it's leaking.I have to change mine after I get it back from the body-shop,and I might do a "how to".
Posted: Fri Nov 30, 2007 10:21 pm
by Vibe_dude
its easy to changed the tensioner pulley....but the will have to unhook the engine mount to raise the motor up so u have room to get in there at it.but u will have to be careful when u raise up the motor that u dont misaline the cv shaft like what happened to me......now my cv joint clicks all teh time.
