Drivers door rattle
Posted: Thu Nov 29, 2007 7:34 am
by theodo155
I have a 03 vibe with 85000 miles. The other day I started noticing a rattle coming from my driver side door. Only happens when the engine is idling. Well today it has gotten worse. Any time you are sitting at a red light the noise is pretty loud. Any one have any thoughts before I pull the door apart?
Posted: Thu Nov 29, 2007 1:53 pm
by northvibe
i bet a clip or somethign fell into the bottom of the door and is rattling.... or a window bolt..if your window does that crazy pop thing
Re: (northvibe)
Posted: Fri Jan 11, 2008 4:16 am
by p8md
Ok, my new 2008 (only a month old with only 2000 miles) has a rattle in the passenger side door (i'm pretty sure). When I lower the window a little it goes away. It's driving me nuts!!!Is this something you could take to the dealership under warrantee? Would you take it to the dealership? Does anyone know of a definite remedy that I could do myself?
Re: (p8md)
Posted: Fri Jan 11, 2008 4:24 am
by Sublimewind
Pull the door panel and have a look-see...
Re: (Sublimewind)
Posted: Fri Jan 11, 2008 4:26 am
by NibCrom
My door (or the left dash) rattles at idle sometimes too. But it's very inconsistent. Happens sometimes on other parts of the dash too.
Re: Drivers door rattle (theodo155)
Posted: Fri Jan 11, 2008 4:55 am
by hskater26
my window did that crazy pop when i first got it and i pulled the door off and one of the bolts was lose making it pop up against the window
Posted: Fri Jan 11, 2008 5:57 am
Are you sure the rattle is in the door? I had a rattling sun visor in my G6 and for quite a while, I was positive the rattle was coming from either the dash, or the passenger seatbelt. Turns out the acoustics of the passenger cabin made the sound bounce around so much I couldn't pinpoint it until one day when I grabbed the visor to put it down and all of a sudden, I had silence. Point being, the rattle could be somewhere else, but just *sound* like the driver's door.For the person with the 08, yes, squeaks and rattles are covered under the initial 3/36 warranty. if you are out of warranty (or have an extended powertrain warranty), you can either track it down and repair it yourself, or pay to have the dealership attempt to resolve it for you.
Re: (ragingfish)
Posted: Fri Jan 11, 2008 6:32 am
by piecuch1
I also had the pop sound when the window would go down. Tightened the loose bolt on the bottom of the window frame and all is good. Maybe the rattle is from the bolt having fell off and is rolling around in the bottom of the door frame?
Re: (ragingfish)
Posted: Fri Jan 11, 2008 11:03 am
by hskater26
Quote, originally posted by ragingfish »Are you sure the rattle is in the door? this is true i had a rattle i swore was in my dash or near my seat and i figured out if i press on the screw that holds our overhead light plastic surrounding piece in place it goes away haha...... i havent found a solution for it yet though
Re: (hskater26)
Posted: Fri Jan 11, 2008 9:49 pm
by MaxxVibe
loosen it up and tuck some paper or a small piece of debris in behind it to give it a buffer between it and whatever its rattling against.
Re: (MaxxVibe)
Posted: Fri Jan 11, 2008 10:43 pm
by kevera
Well I have the opposite of you guys,mine rattles only when it's down.It's been like that since new,and I've got used to it,Toyota= quality.
Re: (Sublimewind)
Posted: Sat Jan 12, 2008 1:22 am
by p8md
Does the door panel come off with the typical 1 or 2 screws around the handle and the plastic retaining clips all around?
Re: (p8md)
Posted: Sat Jan 12, 2008 10:00 am
by JohnC
Look here for door panel removal.http://forums.genvibe.com/zerothread?id=24086
