2005 and up supercharger?
Posted: Sun Nov 18, 2007 1:32 am
by KrazyB
I was just wondering if there was a trd supercharger or similar for the 2005 vibes. I thought that I read about one through GM a year ago but now I can not find it. Thanks in advance guys.
Re: 2005 and up supercharger? (KrazyB)
Posted: Sun Nov 18, 2007 1:38 am
by kevera
It's the same,but you will need a plate for the throttle-body.And you will need some type of engine management because you can't use the Turd ECU.Here's a link to search the adaptor plate.
http://forums.genvibe.com/zerothread?id=30399
Posted: Sun Nov 18, 2007 1:40 am
by BlueCrush
The '05+ Vibe Base uses the same supercharger as the '03-'04 Vibe Base, BUT because of the new electronic throttle (DBW - Drive By Wire), you will need to get an adapter plate and use an e-manage or Unichip to control the 5th injector for the s/c. You can read up on how to supercharge your '05-'08 DBW Vibe Base here:
http://9thgencorolla.com/forum...46356
Re: 2005 and up supercharger? (BlueCrush)
Posted: Sun Nov 18, 2007 1:42 am
by kevera
I already posted that.Plus this is in the wrong section.
Re: 2005 and up supercharger? (kevera)
Posted: Sun Nov 18, 2007 1:48 am
by BlueCrush
Quote, originally posted by kevera »I already posted that.No one posted when I looked here. So Sorry!
Posted: Sun Nov 18, 2007 1:50 am
by kevera
No apologies needed,bro.You actually gave him a direct link,so it was better. I just wanted to tell him there is a forced induction section that this should be under.
Posted: Sun Nov 18, 2007 2:01 pm
by Kamikaze
What would we do w/o the both of you?Nice job guys on pointing Krazy B in the right direction.
Posted: Mon Nov 19, 2007 6:49 am
by 4azdmunky
I just installed one this last weekend in my 05 base auto.The writeup on 9thgencorolla is excellent. You do need the adapter plate (~$176 shipped). I went with the e-manage blue for 5th injector management. Also get the boomslang harness, its roughly $300 but you don't have to worry about getting it wrong.The only hang ups i had:Could not find a place to mount the support bar.The dip stick goes 3/4 inch to the front and right of the stud, not in front of the stud.OBX crank pulley had to be swapped back out for stock, belt doesn't fit with aftermarket pulleys.5th injector wiring. I used the default wiring from the kit instead of buying a Bosch plug off of ebay. No other part of the ECU kit is used.If using e-manage blue, set jumper #2 to closed from open if your car wont start.Set jumpers 5 and 6 to closed from open. This is required for using e-manage to run your 5th injector.You will need to wire up your 5th injector. Here is a pic:
http://www.9thgencorolla.com/forum/show ... unt=15Maps are a PITA to find: Here is some info:
http://www.9thgencorolla.com/forum/show ... =62125Have a OBDII scanner handy to reset your CES lights and see whats erroring. You want all CEL codes cleared before dyno'ing otherwise your ECU is running in closed loop.Good luck, and BTW, if your looking for good gauges, my neighbor sells Megan gauges, and they match our dash gauges very well. His site is
http://www.boostbuddy.comGood luck! Once you go boost you'll never go back
Re: 2005 and up supercharger? (4azdmunky)
Posted: Mon Nov 19, 2007 7:15 am
by kevera
Glad it worked out for you.I'm curious why the support bracket didn't fit,it wasn't long enough or there wasn't a threaded bolt hole for it.I don't like how my dipstick sits but I'm not to worried about it.Boost FTW.
Posted: Mon Nov 19, 2007 7:16 am
by keithvibe
sounds like someone got my Supercharger.. LOL Dino that baby and let us know what your pushing with the e-manage.
Posted: Mon Nov 19, 2007 7:26 am
by 4azdmunky
honestly, i couldn't figure out where to bolt it too. i found the bottom bolt, but could not find the top bolt. If anyone knows where the top bolt is, please attach a picture, it makes me nervous that I don't have that on.
Re: 2005 and up supercharger? (keithvibe)
Posted: Mon Nov 19, 2007 7:31 am
by 4azdmunky
I'm curious too, right now its running way rich and falls on its face from 60 up if i gun it.
Posted: Mon Nov 19, 2007 7:50 am
by BlueCrush
You should get it DynoTuned asap!
Posted: Mon Nov 19, 2007 8:08 am
by kevera
Quote, originally posted by BlueCrush »You should get it DynoTuned asap!1+You'll blow your motor if you don't sorted that out quick.I'll try to get a pic up tomorrow for you regarding the mounting bracket.The reason I was asking about this was because I was wondering if the newer blocks have the hole for it.
Posted: Mon Nov 19, 2007 8:11 am
by 4azdmunky
the one for the bottom was easy, i just couldn't find the one for the top. The 9thgencorolla directions stated that there was one there holding a spot but not used. I didn't see it.....mabey i need a refund on my LASIK.
Posted: Mon Nov 19, 2007 8:18 am
by 4azdmunky
I worried about that too. However I'm running rich, so I figured I have a little wiggle room. I'm also running with water injection. I have no pinging just crap power and a CEL about beign too rich.
Posted: Mon Nov 19, 2007 8:22 am
by kevera
Running too rich is just as bad as running too lean.Detonation!
Posted: Mon Nov 19, 2007 12:12 pm
by KrazyB
Thanks for the links and all the help guys. Allways helpful as allways.
Posted: Tue Nov 20, 2007 12:59 am
by 4azdmunky
I'm going to recheck my e-manage settings and report them here. I posted the previous from memory and it may not be accurate. I'll try to get them back in this thread today.
Posted: Tue Nov 20, 2007 1:16 am
by xrs06
You should get a wideband o2 sensor to know the real condition. Without one, you're blind!If you run too rich (in the 9's of afr), you'll get cylinder wash, which means gas mixed with oil. Really bad for lubrication...
Re: (xrs06)
Posted: Tue Nov 20, 2007 1:28 am
by 4azdmunky
I have one on order, should have it by the weekend, along with a EGT gauge.
Re: (4azdmunky)
Posted: Thu Nov 22, 2007 7:48 am
by xrs06
Get those 2 installed ASAP and come back with some value.It will then be easier for everybody to give you the best advise regarding your problem.
Posted: Thu Nov 22, 2007 2:58 pm
by 4azdmunky
Here are my e-manage settings, these may/or man not work for others, use at your own risk:SW1-4SW2-2SW3-1RSW4-0 (arrow up in center)RSW5-0 (arrow up in center)RSW6-0 (arrow up in center)RSW7-0 (arrow up in center)RSW8-0 (arrow up in center)RSW9-0 (arrow up in center)RSW10-0 (arrow up in center)JP1-1,2JP2-2,3JP3-1,2JP4-OpenJP5-ClosedJP6-ClosedJP7-Closed
Posted: Thu Nov 22, 2007 9:58 pm
by Kamikaze
Consider changing your oil soon too if you're running rich... I had a motor seize up on me from running rich, too much in the oil and could lubricate. Better to be safe on doing an extra oil change than a seized up motor!
Re: 2005 and up supercharger? (Kamikaze)
Posted: Thu Nov 22, 2007 11:24 pm
by 4azdmunky
Very good point for those that are thinking of doing this. Dont risk your engine over a $40 oil change.I did that and added a transmission cooler at the same time.
