pass. side view mirror replacement
Posted: Wed Nov 14, 2007 1:38 pm
by flushing
I bashed my pass side view mirror. Bought a new one on ebay. Anyone have instructions on installing?Thanks '05 5-speed w/ mooon&tunes
Re: pass. side view mirror replacement (flushing)
Posted: Wed Nov 14, 2007 11:10 pm
by Whelan
If you look where it connects to the door, on the inside you will see either a flat plate or tweeter. Take a flathead and pry that off, it will pop out fairly easily. Once that is out you will notice there are 3 bolts, probably 7mm or so in size. Ratched those off and be sure to disconnect the power mirror if you have that option. Typically the bolts are setup a few ways.1) Double sided where the bolt is screwed into the mirror, then the other part is put through the holes in the door and another bolt is added to hold.2) bolts go through the door and into the mirror3) Self tappers.I am not sure which the Trix/Vibe is as I have never replaced a mirror. But most of the cars I have dealt with are the #1 kind with a double ended bolt. If your replacement came with these already your in business, most likely they did not though so just take them off the old mirror and put them on the new, slide into the holes, put on the bolts and hand tighten, connect the power and tighten with a ratchet. Do not torque them like crazy or you will crack them and strip the threads. Just tight enough.
Re: pass. side view mirror replacement (Whelan)
Posted: Thu Nov 15, 2007 12:16 am
by kevera
From what I remember,you have to take the door panel off to unplug the power for the mirror.
Re: pass. side view mirror replacement (kevera)
Posted: Thu Nov 15, 2007 1:02 am
by Whelan
That would be crappy. You can't just pull it up from inside the panel?
Posted: Thu Nov 15, 2007 1:16 am
by kevera
I had to take my door panel off to change my mirror.Hey Whelan,since your here,how can you polish scratches out of the black plastic,my driveway is super narrow and I have some ugly marks on my mirrors.
Posted: Thu Nov 15, 2007 1:19 am
by joholste
kev....get the diamondite stuff...it worked amazingly well on my wifes mirrors
Re: pass. side view mirror replacement (joholste)
Posted: Thu Nov 15, 2007 1:53 am
by Whelan
For surface scratches out of like cladding style plastic, unpainted that is.I would look into the Diamondite stuff. I've never used it personally but I hear a lot of good things about its use.
