Ground wire question for the guys with S/C.
Posted: Wed Nov 14, 2007 3:08 am
by kevera
I just recently bought a set of ground wires,and had a question about where to run the wire for the alternator.Since a new pulley is added, there isn't very much room to safely bolt it on the alternator bracket,as I'm afraid of the clearances being so close to the belt.I don't have any pics,but some suggestions would be great.
Re: Ground wire question for the guys with S/C. (kevera)
Posted: Wed Nov 14, 2007 4:07 am
by Petrucci914
I'll look the next few days and see where the best placement would be. I would think that you'd run it underneath the supercharger, or above it with the wiring harness and then run it through that cut-out channel below the SC cone.
Posted: Wed Nov 14, 2007 8:01 am
by damronjr
Took mine off a LONG time ago, so I have no clue, but didn't want you to think I didn't see the thread or care to respond!
Posted: Wed Nov 14, 2007 8:15 am
by RePo
Do you suppose that the alternator mounting bracket, being solid steel and bolted directly to the engine block, would be an adequate ground already?
Re: Ground wire question for the guys with S/C. (RePo)
Posted: Wed Nov 14, 2007 8:22 am
by kevera
Quote, originally posted by damronjr »Took mine off a LONG time ago, so I have no clue, but didn't want you to think I didn't see the thread or care to respond! Thanks Buddy. Quote, originally posted by RePo »Do you suppose that the alternator mounting bracket, being solid steel and bolted directly to the engine block, would be an adequate ground already?That's a good point.I already have one of the wires on the block itself.That makes me wonder why people say that it's important to run a ground wire directly to the alternator bracket.
Posted: Wed Nov 14, 2007 8:34 am
by northvibe
because those grounds not at the - battery are less than the battery for ground. from noise and things...also you cant really have true ground, but the best ground is at the - battery...so if you ran a cable from the - battery to the alt. it would be a very good ground.
Re: (northvibe)
Posted: Wed Nov 14, 2007 8:45 am
by kevera
Quote, originally posted by northvibe »because those grounds not at the - battery are less than the battery for ground. from noise and things...also you cant really have true ground, but the best ground is at the - battery...so if you ran a cable from the - battery to the alt. it would be a very good ground.How many Redbulls have you had today. That's why I'm asking where to put it,because there isn't any room,in my opinion,to attach it safely without hitting the belt.
Posted: Thu Dec 06, 2007 5:10 am
by BLAQJAQ
lol...kev.. funny you asked about ground wires I just asked blue crucsh about his that he has for sale betwwen the ground wires and boost gauge I'm going to keep you very busy
