Rear Axle Beam Bushings
Posted: Fri Oct 26, 2007 11:49 am
by Mario
http://neverenoughauto.com/ind...=1730Anyone have this mod? I was wondering if it is work the money.Thanks for any assistance.
Posted: Fri Oct 26, 2007 12:37 pm
by northvibe
http://forums.genvibe.com/zerothread?id=28006I asked about them and their other bushings too..... seems like if you really want a tighter ride get them but you'll sacrafice comfort
Posted: Sat Oct 27, 2007 9:10 am
by Mario
No one ever mentioned about installation, though.Any input on the axle busing install?I dont think I would put motor mounts because it is quite involved and I am purchasing performance sway bars, so there goes those busings... unless they're worth it?
Re: (Mario)
Posted: Mon Oct 29, 2007 2:51 am
by Sublimewind
the install can't be that difficult... un-bolt, remove, re-insert and bolt back up... I did poly bushings in my older Subaru and 90% of them were EASY to do... there was that 10% that was a PITA..
Posted: Mon Oct 29, 2007 5:26 am
by northvibe
the rear ones (aka non motor mount ones) should be real easy to install. its just that rear motor mount thats a pain.
Re: (northvibe)
Posted: Wed Oct 31, 2007 10:49 pm
by Sublimewind
Quote, originally posted by northvibe »the rear ones (aka non motor mount ones) should be real easy to install. its just that rear motor mount thats a pain.I do believe he is talking about the rear axle beam, not the motor mounts, but I could be wrong..
Re: (Sublimewind)
Posted: Thu Nov 01, 2007 1:06 am
by northvibe
Quote, originally posted by Sublimewind »I do believe he is talking about the rear axle beam, not the motor mounts, but I could be wrong.. he is, hence the "aka the non motor mount" comment. after that i just stated the mount that IS hard is the rear motor mount...it may of just come out as confusing, i could of been at the bar when i said that or off caffeine.
Posted: Thu Nov 01, 2007 2:17 am
by Sublimewind
Lol......
Posted: Thu Nov 01, 2007 11:10 am
by Mario
So I think I'll try the axle bushings and the motor mounts aswell.All I need is a jack to lift the motor? Where do I lift from?
