2004 Vibe GT Intake Installed
Posted: Sun Oct 14, 2007 2:38 am
by Bocaj77
I installed a intake today on my 04 Vibe GT it was the CAI off of my 03 GT. I cut it down and had to make it a short ram. My question is there is a vacuum line that runs from the intake under the intake manifold over to the passengers side of the engine. This was not on the 03 Vibe GT. For now I just left the vaccum line open and tucked it up. What have others done with this vacuum line??
Re: 2004 Vibe GT Intake Installed (Bocaj77)
Posted: Sun Oct 14, 2007 1:08 pm
by Ninja_Logan
i just left it and i got a CEL, so i reset my ECU and plugged it hoping it would solve the issue but it came back again. So im takin mine to get the codes pulled asap. but if you get a CEL take it in to get the codes pulled asap. otherwise your golden!
Posted: Sun Oct 14, 2007 1:16 pm
by ajflan
Do you have any pics of the aforementioned line?
Re: 2004 Vibe GT Intake Installed (Ninja_Logan)
Posted: Sun Oct 14, 2007 8:14 pm
by Bocaj77
I read the code it was a lean code. And its a small vacuum line that runs under the intake manifold from the stock air box.
Posted: Mon Oct 15, 2007 9:40 am
by Petrucci914
I thought the 04 GT had an air pump, so it had an extra part needed to hook to the intake. So you need to buy one for your year.
Re: 2004 Vibe GT Intake Installed (Petrucci914)
Posted: Mon Oct 15, 2007 7:16 pm
by vibegtcouple
on my i but the cai on i but a dent right at the point were the air pump would hit it fits good . the hose is for your egr i think. you car go to az and get a vac . print out to see what it go to .
Re: 2004 Vibe GT Intake Installed (vibegtcouple)
Posted: Mon Oct 15, 2007 7:23 pm
by vibegtcouple
herhttp://forums.genvibe.com/zerofile/10726/CIMG2069.JPGe is where the fliter came out
Posted: Thu Oct 18, 2007 10:44 am
by Bocaj77
I figured it out, you take that vacuum line and attach it to the nipple under the throttle body.
