Rear 02 JP mind pipe owners
Posted: Sat Oct 06, 2007 2:26 pm
by vibe Freak
Can it be moved further back with out cutting the wires ? I have a new exhaust and cat and need to move it to turn the check engine light off.
Re: Rear 02 JP mind pipe owners (vibe Freak)
Posted: Sun Oct 07, 2007 7:31 am
by satur9
yes. you unplug the harness in the car under the pssenger side carpet by the center console. and pull the rubber body grommet and o2 sensor off. theres is a second body grommet further back under the passengers feet.use that.you may have to undo the little clip holding the harness and it still is a little tight.buty it will make it(for the jp) if yours is farther back you may look into an 02 sensor extension harness if you dont want to cut wires.
Re: Rear 02 JP mind pipe owners (satur9)
Posted: Tue Oct 09, 2007 10:51 am
by vibe Freak
Thanks for the info. it worked out great and the car pulls like crazy.
