Disable key chime?
Posted: Fri Sep 28, 2007 9:38 pm
by gary1212
I dislike all the chimes in my 2006 Vibe and long ago came here and learned how to get rid of the seat belt reminder chime. I would like to know how to disable the annoying chime when the key is in the ignition and the door is open. I did manage to get rid of the chime by defeating the dome light switch but it also disables the dome light. Is there a way to simply disable the chime and have everything else work ?
Re: Disable key chime? (gary1212)
Posted: Fri Sep 28, 2007 10:50 pm
here's the reminder circuit PDF from a 03, the connector pinout of the instrument cluster may be different on an 06. Might be easier to glob a bunch of something on the back of the instrument cluster to mute the chime, or maybe you can cut the wire between the cluster and the "unlock switch".
Attached files 042krlr.pdf (31.4 KB)
Posted: Sat Sep 29, 2007 3:33 am
by ajflan
I personally feel that the seatbelt chime is there for a reason. I don't understand the point of going through the effort to disable it when it is there for your saftey. Seatbelts save lives.
Re: Disable key chime? (ajflan)
Posted: Sat Sep 29, 2007 4:35 am
by 808 Vibes
I hate the wimpy horn more than I hate the chime
Re: Disable key chime? (HawaiiPontiacLover)
Posted: Sat Sep 29, 2007 7:06 am
by keithvibe
Quote, originally posted by HawaiiPontiacLover »I hate the wimpy horn more than I hate the chime HAHAHAhella's baby.... i have seen people jump
Posted: Sat Sep 29, 2007 10:18 am
Quote, originally posted by gary1212 »I would like to know how to disable the annoying chime when the key is in the ignition and the door is open.You *could* just turn the key to ON (without starting the engine) and it will stop the chiming.
Posted: Sat Sep 29, 2007 10:19 am
by WaveAction
or just leave the key out of the ignition when the door is open
Posted: Sat Sep 29, 2007 11:01 am
by ColonelPanic
I've heard of people cutting the leads on the buzzer itself, not something I'd ever recommend in a zillion years as you've whacked all the beeping if you do that. It is soldered onto the cluster's circuit board.Or like raging said and turn the key on. You're going to have more of a drain on the battery though, so be careful if you do that.A small amount of foam camper tape over top of the buzzer will probably help quiet it down too.
Posted: Sat Sep 29, 2007 11:55 am
for me, the chime has saved my battery several times, I can deal with it, wouldn't disable it.If you do disable it, do it in a reversible manner, that way, a month after you trade or sell the car, we won't have a noob on here unable to figure out why the light and door chime in their used 06 Vibe doesn't work
Re: Disable key chime? (keithvibe)
Posted: Sat Sep 29, 2007 1:31 pm
by 808 Vibes
Quote, originally posted by keithvibe »HAHAHAhella's baby.... i have seen people jump Describe it...is it like taxicab loud? Semi loud? LOL
Posted: Sun Sep 30, 2007 10:06 am
by Moocow8
Yea on my vibe the chimming is annoying, i dont mind the seatbelt one unless i have my bookbag there and i end up buckling that in, but wen im vacumming my car out i have the key set to on and the door open and im tryin to listen to music but the chime is killin me
Re: (Moocow8)
Posted: Sun Sep 30, 2007 10:27 am
Quote, originally posted by Moocow8 »but wen im vacumming my car out i have the key set to on and the door open and im tryin to listen to music but the chime is killin meif it continues to beep you do not have the key ON, you have it in ACC. You have to go one position past ACC to ON (without hitting ignition) to have the accessories work without the continuous chiming.
Posted: Mon Aug 25, 2008 3:39 am
by frankb3
the solution
