Fogs
Posted: Sat Sep 22, 2007 11:43 am
by Digger
Anyone know how to turn the fogs on all the time (when car is running)? I would like to have them turn on when I start the car no matter if it is day or night and if the High beams are on. Also I would like to keep the switch working so they could be turned off If needed.Mainly I would like them on when the DRL are on.
Posted: Sat Sep 22, 2007 11:47 am
by WaveAction
no clue..but i would love to find out aswell..i notice even with the headlights on and it's sunny out..the fogs dont come on..which blows
Posted: Sat Sep 22, 2007 12:26 pm
Re: (ragingfish)
Posted: Sat Sep 22, 2007 11:03 pm
by Digger
continuing from Ragingfish's link (Thanks)If you take the org/grn wire and run it to a relay that grounds that wire when the car is in IGN or ACC on the key, the fogs sould go on all the time provided the key is on.Right?GRN/ORG to relayrelay to groundrelay power to ACC via fuse box under dash
Re: Fogs (Digger)
Posted: Sun Sep 23, 2007 3:35 am
by djb383
Why? They're FOG lights. That's why they're down low, not up high, like driving lights. They shouldn't be on unless it's foggy. All they do is cause EXCESS GLARE to oncoming traffic, provide zero improvement in night time vision (unless it's foggy of coarse) and place more load on the engine for less performance and lower mpg. They're irritating to oncoming traffic. There is a reason why they don't come on, when the high beams are on.
Re: Fogs (djb383)
Posted: Sun Sep 23, 2007 5:58 am
by Digger
Thanks for telling me how you feel..... The ansewer to your ? is because I want them to be on. I plan on putting amber bulbs in them which should cut the glare .
Re: Fogs (Digger)
Posted: Sun Sep 23, 2007 6:29 am
by djb383
............but you don't have to look at them in oncoming traffic, like other drivers do.
Re: Fogs (djb383)
Posted: Sun Sep 23, 2007 9:21 am
by Digger
They are on now ( Stock) at night. I rarely keep the brights on in traffic
Re: (Digger)
Posted: Sun Sep 23, 2007 9:23 am
by Digger
Quote, originally posted by Digger »continuing from Ragingfish's link (Thanks)If you take the org/grn wire and run it to a relay that grounds that wire when the car is in IGN or ACC on the key, the fogs sould go on all the time provided the key is on.Right?GRN/ORG to relayrelay to groundrelay power to ACC via fuse box under dashback on topic
