Lower sound from IPOD with Peripheral install than from CD
Posted: Fri Sep 21, 2007 6:15 am
by doggums
Hi AllI am fairly certain that I read about a fix for having lower sound level from a hardwired IPOD setup - i think by dipswitch adjustment, but I can't for the life of me find it. Any help? The CD sound makes my ears bleed when maxed out, and the IPOD is only loud - I wants my ears to BLEED!
Re: Lower sound from IPOD with Peripheral install than from CD (doggums)
Posted: Fri Sep 21, 2007 6:29 am
by kunkstyle
How did you hardwire it? Via the headphone jack, or through the dock output?
Posted: Fri Sep 21, 2007 6:33 am
by doggums
Had it done by bestbuy - used the Peripheral IPOD2CAR unit - don't know what they wired it to. Found a similar problem that another was having here http://forums.genvibe.com/zerothread?id=24690 and for them it was just having the soundcheck function on the ipod itself set to ON - limits the high end to normalize - checked mine and mine was ON too, haven't checked it in the car yet, guessing that was it. Will update later.
Posted: Fri Sep 21, 2007 9:48 am
by coldmm803
i have the same "issue" with my PIE aux adapter. i just deal with it, its no really an issue for me and it was cheaper to get the aux adapter than buy a new head unit
Posted: Fri Sep 21, 2007 12:54 pm
by doggums
turning off soundcheck fixed it for me, my ears are bleeding a gain!
Posted: Fri Sep 21, 2007 1:27 pm
by jwalcik
With my old head unit, I used an basic aux input with output from the iPod's headphone jack. I had to set the volume on the iPod at a certain level (about 3/4's of the way up) to make the volume the same between iPod, CD, and radio. With my newer head unit that has full iPod integration, I'm getting a line-level output from the iPod's dock connector, and there's no volume difference between sources. It may come down to how you're getting the music out of the iPod.
Posted: Mon Sep 24, 2007 5:09 am
by Atomb
not sure about the iPod2CAR, but the PIE aux adaptor (coldmn803) can increase its volume by switching DIP #6 to 'ON'.see toward the end of this thread: http://forums.genvibe.com/zero...age=4
