Page 1 of 2
Belt Tensioner Pulley Replaced. No more rattling....woot!
Posted: Tue Sep 11, 2007 3:01 am
by BlueCrush
Had my belt tensioner pulley replaced under warranty today. Ah, the sweet sound of a non-rattling tensioner pulley.
Posted: Tue Sep 11, 2007 4:28 am
by Sublimewind
S W E E T
Re: Belt Tensioner Pulley Replaced. No more rattling....woot! (BlueCrush)
Posted: Tue Sep 11, 2007 6:15 am
by kevera
Must be nice to have a warranty left It's all your fault.j/kI will need to do this soon as I noticed my bushing had a little slop in it.
Re: Belt Tensioner Pulley Replaced. No more rattling....woot! (kevera)
Posted: Tue Sep 11, 2007 9:39 am
by BlueCrush
My warranty bumper to bumper warranty is done in a month (I'll be at 3 years) so I'm glad I got this taken care of before then. Kev, glad I could help you to lose your warranty. lol.
Posted: Thu Jul 16, 2009 12:24 pm
AOTOTB Attack of the old thread bump. So what kind of sound does a failing tensioner make, and are there any visual things to see to help me figure out if the sound I'm getting is the tensioner or something potentially more serious? Tensioner is too pricey to just swap and see if the noise goes away.
Posted: Thu Jul 16, 2009 3:56 pm
by Sublimewind
I think mine is going, it's more pronounced when it's really cold, but If it's what I think it is, it makes the car sound like a diesel.. with that "rattle".. engine speed dependent also..
Re: (joatmon)
Posted: Thu Jul 16, 2009 8:15 pm
by BlueCrush
It will sound like marbles in a plastic cup. Mine is acting upagain so I aill be replacing only the piston part of the tensioner. Part cost $35 on ebay. We'll see if that takes care of it.
Posted: Fri Jul 17, 2009 12:31 am
oh well, mine is more when it's warm, more of tap, almost a knock or pop, not really a rattle. I'll check the exhaust manifold/pipe for a leak, then it might be internal. Sound seems to be coming from betweeen the engine and the firewall, between the manifold and tensioner (the passenger side) more obvious under load, which is hard to check on a MT car with your head under the hood. When the tensioner is going, do you see the belt flutter? I pulled the belt off and ran it, couldn't recreate the sound, put the belt back on, couldn't recreate the sound, next day normal driving sound was back. When I took the belt off, the tensioner was hard to move at first, kinda like it was stuck in position. Easier to move after I moved it the first time.
Re: (joatmon)
Posted: Fri Jul 17, 2009 12:43 am
by BlueCrush
Quote, originally posted by joatmon »When the tensioner is going, do you see the belt flutter? I pulled the belt off and ran it, couldn't recreate the sound, put the belt back on, couldn't recreate the sound, next day normal driving sound was back. When I took the belt off, the tensioner was hard to move at first, kinda like it was stuck in position. Easier to move after I moved it the first time.No, my belt doesn't flutter at all. but one way to check it would be to grab the belt (with the car off and the engine cool, for obvious reasons) and move(wiggle) it as much as you can up and down it should recreate the noise if it is the tensioner. It won't sound like several marbles in a cup as if it was running but it should sound like 1 marble in a cup.
Posted: Fri Jul 17, 2009 7:43 am
by Vibe_dude
It is a known problem with these Toyota cars,they all will wear out.So much for Toyota quaility.lol
Re: (BlueCrush)
Posted: Sat Jul 18, 2009 1:05 am
Quote, originally posted by BlueCrush »No, my belt doesn't flutter at all. but one way to check it would be to grab the belt (with the car off and the engine cool, for obvious reasons) and move(wiggle) it as much as you can up and down it should recreate the noise if it is the tensioner. It won't sound like several marbles in a cup as if it was running but it should sound like 1 marble in a cup.alas and alack. when I shake the belt hard all I get is a slight sqishy sound, like a spring loaded hydraulic damper doing it's job.I thought maybe an exhaust leak, but after replacing the donut between the manifold and converter pipe which was visibly worn, it had no effect and the sound is unchanged. I don't really want to do it, but I guess the next thing for me to check is the rod bearings. I'm bummed. oh well, a set of those is cheaper than a tensioner, so I guess I should look on the bright side.
Posted: Sat Jul 18, 2009 1:39 am
by Sublimewind
oh yeah, rod bearings, far easier of a job then the tensioner pulley... lolYou know they go, so why not consider it a PM item.. lol.. you know the front wheel bearings go out a lot too, you can't move them around unless they are REALLY bad... So, if you had a wheel bearing going, you gonna replace the cam bearings?
Re: (Sublimewind)
Posted: Sat Jul 18, 2009 2:04 am
Quote, originally posted by Sublimewind »oh yeah, rod bearings, far easier of a job then the tensioner pulley... lolYou know they go, so why not consider it a PM item.. lol.. you know the front wheel bearings go out a lot too, you can't move them around unless they are REALLY bad... So, if you had a wheel bearing going, you gonna replace the cam bearings?I've got a sound related to engine speed that I can replicate sitting still, it's almost a knock, a bit duller than a tap, when not under load, I can replicate it by revving the engine and letting go, and as the RPMS top out and begin to fall off, I get the sound a dozen or two quick knocks, solid but not a hard knock, duller than a tap. When I wiped a rod bearing in a Chevy 350 it sounded like someone beating on the engine with a sledgehammer, this is not that bad, but it's not the chatter of a valve. testing after replacing the donut today I am fairly sure it is not as fast as it would be if it was something from all four cylinders, but maybe as fast as just one of them. Regular service/oil changes, but it's a high mileage that has not been babied so a worn rod bearing is not out of the question, and I'm going through the easy things first before i do that. 03vibe-GT replaced his rod bearings by dropping the pan, 1zz and 2zz won't be that different on the bottom, and I've done that in other vehicles with success. Not that you care. Thanks for the ridicule.
Posted: Sat Jul 18, 2009 2:18 am
by Sublimewind
Sorry about that man, but it really did seem Ridiculous.. I'm not saying you are incorrect in your assumption.. the part may be cheaper, the job sure isn't... What would make you think you spun a bearing? You don't "hot rod" around in your vibe... you take VERY good care of it... I know ish happens, but it's very unlikely.. And really, I DO care... you wouldn't see my SN so much in the tech sections if I didn't... can't deny that, right?
Re: (Sublimewind)
Posted: Tue Aug 11, 2009 9:28 am
by BlueCrush
The tensioner rattle came back many, many months ago so I FINALLY replaced just the piston tonight. Super easy and the part was only $35 from Ebay. No more tensioner rattle. Nice and quiet during idle and light acceleration.
Re: (BlueCrush)
Posted: Wed Aug 12, 2009 9:19 am
by keithvibe
Quote, originally posted by BlueCrush »The tensioner rattle came back many, many months ago so I FINALLY replaced just the piston tonight. Super easy and the part was only $35 from Ebay. No more tensioner rattle. Nice and quiet during idle and light acceleration. so where the heck is the write up with photos????
Re: (keithvibe)
Posted: Wed Aug 12, 2009 9:55 am
by BlueCrush
I used the DYI from 9th Gen. I'll copy paste it here:
http://www.9thgencorolla.com/f...02244
Posted: Thu Sep 02, 2010 12:42 pm
by bassrocker032
Well I decided to BUMP this since it's a great thread with a current problem that i'd be willing to bet alot of people face and I dug and couldn't find it but time to bump it up to get this back out there.
Re: (bassrocker032)
Posted: Thu Sep 02, 2010 12:55 pm
by BlueCrush
Great Idea, Bassrocker!!! Since I replaced the tensioner pulley piston on 8/12/09, I have not had a problem at all.
Posted: Fri Sep 03, 2010 1:13 am
by bassrocker032
Is there anywhere with photos of how to do this? I went to 9th gen vibe to the posted link you put BlueCrush but all I could find was a step-by-step walk through. Are there any existent pic threads of how to do this?
Re: (bassrocker032)
Posted: Fri Sep 03, 2010 1:17 am
by BlueCrush
I just used the written instructions when I replaced mine.(no pics)
Re: (BlueCrush)
Posted: Sat Sep 04, 2010 4:00 pm
by vibedrivermatt
thats interesting. My 09 makes a pebbles in a paper cup sound too. It sounds like it's comming from behind the dash. I can hear it best when driving at a pretty slow speed while driving on the slightly rutted dirt driveway going to my parents house. I guess I'll have to give it that test you guys mentioned eariler to see if I can get that one pebble in a cup sound. I dunno if replaceing it would even be a good solution because I'd think it would start making the noise again after 10,000 miles. The noise started happening on my car when it was still pretty new.
Re: (vibedrivermatt)
Posted: Sun Sep 05, 2010 11:37 am
by ou.grizzly
Quote, originally posted by vibedrivermatt »thats interesting. My 09 makes a pebbles in a paper cup sound too. It sounds like it's comming from behind the dash. I can hear it best when driving at a pretty slow speed while driving on the slightly rutted dirt driveway going to my parents house. I guess I'll have to give it that test you guys mentioned eariler to see if I can get that one pebble in a cup sound. I dunno if replaceing it would even be a good solution because I'd think it would start making the noise again after 10,000 miles. The noise started happening on my car when it was still pretty new. It may be the plastic shroud under the windshield wipers on the outside, as mine makes that noise at times.
Posted: Thu Oct 07, 2010 10:21 am
by burns
I have a 2008 with the ol' marbles in a cup feeling. I want to try replacing just the piston but I can't find one for the '08, they all go up to '07. Does this suggest that the '08 has the particular tensioner with the permanently attached piston?
Re: (burns)
Posted: Fri Oct 08, 2010 12:29 pm
by bassrocker032
Before you go off doing that, check this out. And this is also to everyone as a public look the **** out. I found out what my marble in a cup sound was. Turns out when I got my engine swap, they forgot to put a bolt on my a/c compressor so out of the one bolt on top and the two on bottom I had one on top and one on bottom allowing the compressor to rattle, eventually leading to the top bolt breaking off into my engine block. CHECK THIS PLEASE. Just check to make sure all the bolts are on there tight and that they're all there. I had to get the bolt out of my engine block and replace two of the three 1.25 thread bolts thanks to my local hardware store. But yeah, when the bolt broke off I was only seconds from my house but this compressor bolt breaking led to the compressor falling to the bottom of the engine bay, the belt to come completely off, the engine suck what little radiator fluid was left in only the hose dry until the house bent like when you drink a milk shake and the straw folds up, the battery light came on, the car began to over heat, bladda bladda blah, all that fun stuff. But one broken bolt removal and a few days of work later and I saved a few hundred in labor and repairs at the local shop, along with having an oh so great time getting my hands dirty. i really should've done post on this but i've been suer busy. But yeah, check for that first before replacing anything.
Re: (bassrocker032)
Posted: Wed Oct 20, 2010 3:33 am
by JazzyVibe
For the 03' does the whole tensioner need to be replaced or just the pulley? For 100 bucks should I just replace both? I really don't want to raise up the motor to find that just replacing the pulley wasn't enough.
Posted: Thu Oct 21, 2010 5:24 am
by bassrocker032
Did you see my post talking about the quick check you can do before replacing the tensioner? It's on the first page, but my marbles in a cup problem was a loose bolt holding the ac compressor on rattling and eventually breaking off which could have been very bad. Just a quick check up on the bolts will do good, just to be 100%
Re: (JazzyVibe)
Posted: Thu Oct 21, 2010 5:33 am
by BlueCrush
If it is the tensioner, the cheapest route is to replace the tensioner piston/shock only for $35 (part cost). Mine is still good after replacing just the piston/shock.
Posted: Thu Oct 21, 2010 9:47 am
by matrixjim
Who's a good source for the piston/shock?
Re: (matrixjim)
Posted: Thu Oct 21, 2010 11:43 am
by BlueCrush
I bought mine off EBay.
Posted: Thu Oct 21, 2010 2:20 pm
by Vibe Raider
good info here. I got the diesel sound too when i first start it and when i initially take off. Especially when its cold, so Im gonna try this link you guys put up. As for the noise, what it reminds me of is the noise you make when you breath out your mouth with your lips closed(the vibration sound it makes) ... With that said, do you think i can get away with the cheap route?
Posted: Thu Oct 21, 2010 2:26 pm
by Vibe Raider
Is this the same part you are talking about on ebay?
http://cgi.ebay.com/ebaymotors...ories
Posted: Tue Nov 30, 2010 1:16 pm
by Bastranz
This is great information; thanks for sharing! My Vibe has been doing this since I bought it used, but I just chalked it up to a "quirk" as the sound goes away once the engine gets warmer. Of course, it's a tad embarrassing when driving through the neighborhood first thing in the morning...I wonder if a delay in replacing the belt tensioner piston (or whatever is causing this) could result in immediate serious damage to the engine. So far so good after 19 months.
Re: Belt Tensioner Pulley Replaced. No more rattling....woot! (Vibe Raider)
Posted: Tue Nov 30, 2010 8:43 pm
by BlueCrush
Quote, originally posted by Vibe Raider »Is this the same part you are talking about on ebay?
http://cgi.ebay.com/ebaymotors...oriesSorry, I didn't see this sooner. No, not that part. This one:
http://cgi.ebay.com/ebaymotors...oriesDo a search on Ebay for "Vibe Tensioner"
Posted: Wed Dec 01, 2010 3:41 am
by cptnsolo77
I think my tensioner may be going bad as well. I have some of the symptoms. What creates the noise anyhow? I get a noise when the car is cold then shift it into drive/reverse. Doesnt have the "marble in a can" sound its more like a tapping similar to an exhaust leak. Hmmmm.
Posted: Thu Dec 09, 2010 1:18 pm
by SonicThunder88
Has anyone installed the aftermarket tensioner piston from ebay (as pictured in an above post)?If so, how long have you had it on the car and does it seem to stand up as well as the factory unit?
Re: (SonicThunder88)
Posted: Sun Dec 12, 2010 1:54 pm
by Vibe Raider
I just ordered the part. I believe it was Bluecrush that said he installed it and its held up for a long time. I have probably 90k on the vibe now but the noise has been there for at least 15k. Hoping this will still take care of it. I have high hopes just from what i can tell by looking at the assembly.
Posted: Sun Dec 12, 2010 8:52 pm
by BlueCrush
Quote, originally posted by SonicThunder88 »Has anyone installed the aftermarket tensioner piston from ebay (as pictured in an above post)?If so, how long have you had it on the car and does it seem to stand up as well as the factory unit?Yes.Since 8/11/09.Yes, so far.
Re: (BlueCrush)
Posted: Mon Dec 13, 2010 6:05 am
by skeletron
what is the worse case scenario of this symptom? mine has been doing it for about a month now...
Re: (skeletron)
Posted: Mon Dec 13, 2010 6:13 am
by keithvibe
Quote, originally posted by skeletron »what is the worse case scenario of this symptom? mine has been doing it for about a month now...the belt keeps slipping, or breaks from bouncing. Causing even more damage to the engine.
Re: (keithvibe)
Posted: Mon Dec 13, 2010 8:59 am
by skeletron
what should one expect to pay from a shop to replace it? i found this on ebay:
http://cgi.ebay.com/ebaymotors...38656is that what i would need? and why did the dealer quote my wife $250 for the same part?
Posted: Wed Dec 15, 2010 5:58 am
by skeletron
also, what are the torque specs?
Posted: Thu Dec 16, 2010 2:17 pm
by Vibe Raider
I received the part today described on Bluecrushs link above. Noise is gone. No more Vibe rating. Thanks Bluecrush, that link for the install was excellent. 30 minutes tops install time.
Re: (skeletron)
Posted: Thu Dec 16, 2010 8:52 pm
by BlueCrush
Quote, originally posted by skeletron »also, what are the torque specs?That, I don't know. Sorry. Hopefully, someone else can chime in.Quote, originally posted by Vibe Raider »I received the part today described on Bluecrushs link above. Noise is gone. No more Vibe rating. Thanks Bluecrush, that link for the install was excellent. 30 minutes tops install time.Excellent! Glad it worked out for you.
Re: (BlueCrush)
Posted: Fri Dec 17, 2010 1:10 am
by jkm311
I'm thinking of doing this in the spring. However, I get *both* sounds people have associated with the tensioner: A squeak/squeal at idle (while in drive only), and I get the "diesel/marbles-in-a-cup" rattle in park. Both are subtle, but annoying. Is the squeal attributed to the belt? It would be awesome if I could just put on a new belt (mine's 6 years old, anyhow), then order the tensioner piston only to combat the rattle issue. I have no means to slightly raise the engine and replace the entire tensioner assembly myself, and I don't want to shell out $300+ for someone to do so. Any thoughts?
Posted: Fri Dec 17, 2010 4:31 am
by cptnsolo77
Thats exactly what I plan to do. Im starting to develop a crack here & there on the belt ( has 67K on it ) im going to replace the tensioner piston while im in there. Im in the same boat as you...no means of lifting the engine & im not going to pay someone to do something I can do myself !
Re: (jkm311)
Posted: Fri Dec 17, 2010 6:23 am
by BlueCrush
Quote, originally posted by jkm311 »I'm thinking of doing this in the spring. However, I get *both* sounds people have associated with the tensioner: A squeak/squeal at idle (while in drive only), and I get the "diesel/marbles-in-a-cup" rattle in park. Both are subtle, but annoying. Is the squeal attributed to the belt? It would be awesome if I could just put on a new belt (mine's 6 years old, anyhow), then order the tensioner piston only to combat the rattle issue. I have no means to slightly raise the engine and replace the entire tensioner assembly myself, and I don't want to shell out $300+ for someone to do so. Any thoughts?The squeak could very well be just the belt. I'd recommend getting a Goodyear Gatorback belt and replacing the piston. You may just well eliminate both your issues. And it is the cheapest 1st step to take to try and eliminate it.
Re: (BlueCrush)
Posted: Fri Dec 17, 2010 6:29 am
by jkm311
Quote, originally posted by BlueCrush » You may just well eliminate both your issues. And it is the cheapest 1st step to take to try and eliminate it.Thanks for the info. Added to the list after the snow melts away.
Re: (jkm311)
Posted: Tue Apr 26, 2011 2:08 am
by jkm311
So, just when I was gearing up to give this a go, eBay no longer seems to be a source for these pistons. I've found a GatorBack belt at RockAuto, but no tensioners listed here on eBay. Anyone more savvy than I able to find one lately?
Re: (jkm311)
Posted: Tue Apr 26, 2011 2:32 am
by sideshowalan
I posted this in a similar thread last week.
http://www.amazon.com/Tensione...EVC52
