In the grass
Posted: Sat Sep 08, 2007 12:56 am
by hank the tank
I got my Progress lowering kit yesterday and today it goes on. Any helpful tips. I got impacts and air ratchets. I have to go rent a spring compressor. I think i got everything to do the job. All be sure to get pics.
Re: In the grass (hank the tank)
Posted: Sat Sep 08, 2007 2:03 am
around here Autozone will lend you tools. You have to put down a big cash deposit, but you get it all back when you return the tool. Might be a $0 option for the spring comrpessor rental
Posted: Fri Sep 14, 2007 3:24 am
by Kamikaze
Take your time, when compressing the spring make sure that you go from side to side so that you don't compress too much on one side first.. I don't think I've ever had big problems when putting in springs, just do them one at a time. you'll probably want to check for an alignment when all done.Can't wait to see pics, make sure you do before and after pics!
Re: (Kamikaze)
Posted: Fri Sep 14, 2007 9:47 am
by chevelle_lover
If autozone rents the sprin compressor with just the hooks. Be careful as I have had these slip off. The one that I have bought loops around the spring itself. If I was worried about marking the spring I use electrical tape. The nice thing about the one I have is that it bolts around the spring and it is near impossible for it to slip.
