Gauges(PICS)
Posted: Fri Sep 07, 2007 12:23 pm
by ajflan
Here are my gauges. Unfortunatley, my a/f ratio gage does nothing but freak out. The needle goes from one extreme to another at a very high rate of speed. It is super annoying. If anyone has an idea of why this is occuring, please let me know. Here are the pics.
Posted: Fri Sep 07, 2007 3:10 pm
by CountryVibe
Looks good
Posted: Fri Sep 07, 2007 3:14 pm
by AKLGT
aw well, at least it looks nice. LOL
Re: Gauges(PICS) (ajflan)
Posted: Fri Sep 07, 2007 3:33 pm
by damronjr
Well done!
Posted: Fri Sep 07, 2007 11:41 pm
by kevera
I really like your gauges,how the red matches the cluster.But I'm not crazy about the pods though.How did you connect the a/f gauge?
Posted: Sat Sep 08, 2007 12:03 am
by Celtic_Curse
Looks good!! What Pods did you use? Where can I get some?
Re: Gauges(PICS) (kevera)
Posted: Sat Sep 08, 2007 5:52 am
by ajflan
I had a shop install them. The tech gave me a reason as to why the gauge wont work properly, but I don't remember why. I will be calling them in a few minutes to find out. Celtic, the pods are autometer pods bolted right to the a-pillar.
Posted: Sat Sep 08, 2007 6:33 am
by djb383
.................and oil pressure readings?
Re: Gauges(PICS) (djb383)
Posted: Sat Sep 08, 2007 6:38 am
by ajflan
The oil pressure readings are fine. However, I will have to wait until Monday to find out why my a/f ratio gauge doesn't work properly. The tech won't be back until then.
Posted: Sat Sep 08, 2007 7:32 am
by ajflan
Quote, originally posted by kevera »I really like your gauges,how the red matches the cluster.But I'm not crazy about the pods though.How did you connect the a/f gauge?I just checked, and the a/f gauge is connected to the blue wire of the header o2 sensor. So apparently it is hooked up right.
Posted: Sat Sep 08, 2007 8:29 am
by djb383
Quote, originally posted by ajflan »The oil pressure readings are fine. However, I will have to wait until Monday to find out why my a/f ratio gauge doesn't work properly. The tech won't be back until then.What is fine?........................................and did the A/F gauge come with it's own sendor/sensor?
Posted: Sat Sep 08, 2007 8:58 am
by ajflan
The a/f has a sensor line that taps into the stock o2 sensor. And if you want to know what psi the oil is, I think it was slightly under 20 after the car was warm, but I don't remember for sure. And obviously the pressure builds when I accelerate. I looked around this and other forums to see where people had their a/f hooked up to, and it would seem that mine is hooked up properly.
Posted: Sat Sep 08, 2007 9:28 am
by ajflan
Ok, I did some more reading and found out that this abnormal gauge behavior may in fact be normal. Here is a link to what makes me think that.http://forums.genvibe.com/zerothread?id=18290
Posted: Sat Sep 08, 2007 9:46 am
by kevera
They do move around a bit,but some gauges require this kit to be installed for accurate readings.It's not necessary but some do.http://www.autometer.com/cat_a...d=162
Posted: Sat Sep 08, 2007 10:09 am
by ajflan
How do I find out if my gauge is wide or narrow band?
Posted: Tue Sep 11, 2007 2:10 am
by Sublimewind
It's not the gauge that is wide or narrow band, but the O2 sensor itself.... Hare is the GIS page.. http://www.google.com/search?s...ensorHere is another GIS based on the Bosch LSU4 wideband sensor....http://www.google.com/search?s...+LSU4+Hope this helps mate...Aaron
Posted: Fri Dec 28, 2007 7:29 am
by Celtic_Curse
Hey sorry to resurect this thread but I installed my sandwhich and have nothing but leaks. FIrst the seal then the screws. Has anyone else had issues with this? The gauges work but since i use Mobil1 I can't stop the leak. Any ideas?
Re: (Celtic_Curse)
Posted: Fri Dec 28, 2007 7:32 am
by Celtic_Curse
Also what is everyones oil gauge reading? Mine goes to 20 when warm but when cold it's pinned at over 100. Do these engines run with that high of OIL pressure? Thanks.
Posted: Sat Dec 29, 2007 2:05 am
by Celtic_Curse
bump, does the oil pressure drastically change for anyone else?
Re: Gauges(PICS) (Celtic_Curse)
Posted: Sat Dec 29, 2007 4:26 am
by ajflan
As far as your leak goes, I'm not sure. As for the oil pressure, yes, mine is that dramatic of a difference when its cold and warm as well.
Posted: Sun Dec 30, 2007 11:12 pm
by Celtic_Curse
Thanks buddy I thought I did something wrong on the install. When the engine is cold the pressure needle is buried then as you stated as it warms up It goes to normal...weird. The leak I will hopefully have fixed this week, I am gonna take it to U-wrench where I can fix it properly.
