its on!!!
Posted: Thu Sep 06, 2007 8:06 am
by wyatt89
well, just got my test pipe welded on today and i must say, it makes the vibe sound pretty badass!!there isnt a noticable drop in torque or throttle response and it really pulls when it hits lift.slight popping (every once and awhile) when i get off the gasthe only annoying thing is that the exhaust hits max db/annoyance about at 3k rpms which is where i normally shift overall it makes the vibe pretty fun
Re: its on!!! (wyatt89)
Posted: Thu Sep 06, 2007 8:20 am
by kevera
Can I ask you why you routed it out there.I would have dumped it down,instead of out.
Re: its on!!! (kevera)
Posted: Thu Sep 06, 2007 8:25 am
by wyatt89
because routing it down would have been much too loud for my tastes, it would essentially echo off the road and back into the cabinalso i wanted easier access to it since its a bit hard to get under there for me
Posted: Thu Sep 06, 2007 8:28 am
by kevera
The other question,will you get hassled by the cops with that sticking out.
Posted: Thu Sep 06, 2007 8:32 am
by wyatt89
it doesnt stick out, its just the angle, it sits flushi live in a state with no emissions laws (now) and it is welded in behind the cat anyways so it would still pass emissions *shrug*we'll see although i seriously doubt a cop would care as there are all sorts of diesels and old beater (removed) trucks up here that sound like they are dumped off the manifold its not raspy or tinny sounding so its fine by me
Posted: Thu Sep 06, 2007 10:33 am
by binary
Um.. hrm.Is it like a Y pipe that you have the ability to open your exhaust to the pip in the picture and close it up and send it through the muffler? Or is it just open all the time?
Re: (binary)
Posted: Thu Sep 06, 2007 10:46 am
by wyatt89
the exhaust has a choice of where to go, so path of least resistance tells it to go out the test pipe although a small amount still goes through the muffler. i had a hole cut into the exhaust pipe and a pipe welded off of that at an angle...the valve version of a test pipe is more expensive and more prone to leaking/failure, mine just has a cap that i bolt onto the end that seals it and routes it through the muffler only.
Posted: Thu Sep 06, 2007 2:06 pm
by Vivid_Art
(removed)? no emission laws, thanks jerks for global warming!...j/k( I still think its wrong). So Wyatt does that help your thin air problem at all?
Posted: Thu Sep 06, 2007 9:32 pm
by Raivis
i too had and still have a slight popping when letting off the gas. had mine on for a yr. i believe its just a little backfire. mine has been off for bout a yr and a half and nothing has gone wrong
Re: (Vivid_Art)
Posted: Fri Sep 07, 2007 4:17 am
by wyatt89
umm, i would say that it seems to help a bit at high rpms, i really need to do an air intake though...the vibe sounds pretty good though anyways, yah coming from texas we have fairly strict emissions there but technically my car would still pass emissions since it is dumped after the cat *shrug*
Re: (wyatt89)
Posted: Fri Sep 07, 2007 2:57 pm
by ajflan
Dude that is awesome. You should post some sound clips. I don't know why, but I like the popping and gurgling sounds an uncorked exhaust makes.
Re: (ajflan)
Posted: Sun Sep 09, 2007 7:27 am
by wyatt89
haha, yah i know what you mean, im not sure how i would get a sound clip except my phones voice recorder but that would freak out at the noise...i could use my computer...ill try soon
Posted: Tue Sep 11, 2007 4:40 am
by Sublimewind
Digital camera in movie mode??
Re: (Sublimewind)
Posted: Tue Sep 11, 2007 11:48 am
by wyatt89
i dont own one...i shoot all slides...
