Radio Bezel question
Posted: Sun Sep 02, 2007 5:49 am
by peanshe
I have an 06 AWD and so far love the thing for the most part. However the radio bezel has started to rattle and is extremely annoying. It rattles on the bottom right corner and goes away when pressure is applied to it. I would think that the clip holding it in is loose, but when I go to pry the bezel off it feels like it will break. Should I just stop being a baby and rip it off or is there a specific way to remove it so I can stop the rattle?http://forums.genvibe.com/zerofile/9413/radio.pdf this kind of helped, but it says to use a specific tool that I do not have. I could try a screw drive I guess.Also does anyone else have problems with weatherstripping falling off? It was extremely cold last winter and I wonder if that is why some of it started to sag.
Re: Radio Bezel question (peanshe)
Posted: Sun Sep 02, 2007 5:54 am
by Raven
Pull out on the bottom with both hands and the clips should let go, then lift it up off the top hooks. If it's still under warranty, get the dealer to do it. If they break it, they'll replace it. Same for the weatherstripping, dealer fix.Welcome to Genvibe!
Posted: Sun Sep 02, 2007 5:56 am
by 02csnow
I have taken my radio bezel off a few times and when I have taken it off. I grab a hold of where the vent is and pull that part out first and then work around. I believer there are 4 clips holding it in.
