gm supercharger for an 07
Posted: Mon Aug 13, 2007 9:37 pm
by rendar
we love our 03 vibe so much we're going to get a 2nd one. A new 07. i want to have the gm supercharger installed prior to pick up. my question is that the performance catalogue lists the kit for 03-04 only.Will this kit work/fit on an 07? I work for the dealer and we're having a tough time figuring out if there will be any troubles.
Re: gm supercharger for an 07 (rendar)
Posted: Mon Aug 13, 2007 10:28 pm
by Toasted7
As far as I know, an 03-04 supercharger will NOT work on an 05 and up because of the "drive-by-wire" throttle-body. I could be wrong, but someone will come along and let us know for sure... they always do, cause genvibe people are good like that.
Posted: Mon Aug 13, 2007 10:38 pm
by coldmm803
yes it can be done, its not the same "easy" bolt on for the 05+ as it is for the 03 and 04's because you need an additional bracket/plate to be fabricated.you can try searching for some info. the guy that figured out how to make the bracket is not a vibe owner, hes one of the corolla or matrix guys (i dont remember)welcome to the board
Posted: Mon Aug 13, 2007 10:49 pm
by BlueCrush
You will also need to use an E-manage or Unichip to control the A/F as the TRD S/C ECU is only set-up for the '03-'04.
Posted: Tue Aug 14, 2007 1:29 am
by rendar
Hmm, mods to brackets, ECU changes...not as simple as i was hoping. Don't know if i want to mess too much with an 07. if i didnt have 200,000k on the 03 i'd sc it with the factory unit.
Re: (rendar)
Posted: Tue Aug 14, 2007 6:35 am
by Lancer
Psst...turbo
Posted: Tue Aug 14, 2007 9:13 am
by Raven
The adapter plate goes between the throttle body and the supercharger. It sells for about $100.00. Greddy E-Manage will run about $400.00 Cnd plus you need a bunch of wiring harnesses. I doubt you will find a supercharger at any dealer because they quite making them. Also your warranty would not cover the supercharger or any related engine failures. You should do a search of all Canadian dealers for a leftover new Vibe GT. You will have the same power without all the hassles.
Posted: Tue Aug 14, 2007 9:33 am
by rendar
Thanks for all the info. I'm going to leave the 07 stock. It'll be fun to compare the 03 to the new one.when my wife let's me drive it.
Re: (rendar)
Posted: Tue Aug 14, 2007 11:09 am
by djb383
Put the huffer on the '03 and have a blast.
Posted: Tue Aug 14, 2007 1:09 pm
by northvibe
+1 to SC the 03!!
Re: (northvibe)
Posted: Wed Aug 22, 2007 7:32 am
by vibe Freak
S/C the 03
