Pre-Cataytic Converter
Posted: Mon Aug 13, 2007 11:17 am
by Petrucci914
Hey,I'm thinking about replacing my Pre-Cat and just eliminating the second one. I shouldn't get a CEL with that, right? One O2 sensor is in the header and the other is after the Pre-Cat so it should be fine, correct?
Posted: Mon Aug 13, 2007 11:19 am
by northvibe
i think bluecrush did something similar.... of course there should be some other people that did some custom exhaust that will post up though!
Re: Pre-Cataytic Converter (Petrucci914)
Posted: Mon Aug 13, 2007 10:47 pm
by BlueCrush
I hollowed out my precat, which is built into the AWD header. I then replaced my second oem cat with a Magnaflow high flow cat. I kept getting the P0420 CEL code until I installed the Camcon and roughly tuned the A/F.
Posted: Tue Aug 14, 2007 12:40 am
by manicdan
what kind of changes would i see on my 05 GT if i were to get a better cat?
Re: (manicdan)
Posted: Tue Aug 14, 2007 12:58 am
by Petrucci914
Less Meowing, and more power, better gas mileage, etc.
Posted: Tue Aug 14, 2007 1:08 am
by drunkenmaxx
actually i've seen tests where a high flow cat only added about 1hp over stock
Re: (drunkenmaxx)
Posted: Tue Aug 14, 2007 1:11 am
by Petrucci914
A horse is a horse. You'd probably see a better result with the fuel mileage. My Vibe was one of the first sets made and I'm guessing the Cat was never replaced under that TSB. So I kinda wanna get it taken care of.
Posted: Tue Aug 14, 2007 11:06 am
by tribalman
is it possible to pull out the dual cat we have and just put in a single stage cat? would there be any benefit? sometimes if i'm driving for more than 45 minutes around the car is really warm and sometimes has an egg/fart smell.
Re: Pre-Cataytic Converter (tribalman)
Posted: Tue Aug 14, 2007 11:08 am
by Petrucci914
If you're under 80k miles then bring it in under the TSB and they'll replace your ECU and catalytic converters for free.
