				Thermometer Calibration?
				Posted: Mon Aug 06, 2007 11:00 pm
				by mycar
				My 2005 Vibe's External temperature display seems to be consistently 3 degrees too high. Anyone know if this can be calibrated? Thanks
				Re: Thermometer Calibration? (mycar)
				Posted: Mon Aug 06, 2007 11:09 pm
				by GrayFox
				that's pretty common for Vibes... I'm not sure about recalibration tho.
				Posted: Mon Aug 06, 2007 11:39 pm
				by RIT
				How do you know that it is off by 3 degrees.  It is telling the temperature of the air above the road, and that is, most likely, warmer that the weather station's reported temperature, because it is probably in the sun, and heated up by cars, etc.  Try sticking the sensor in a cup of ice water, and see what temp you get.  I doubt if the digital thermometer is inaccurate - seems like Pontiaoyta ought to be able to get that correct !
				Posted: Tue Aug 07, 2007 12:23 am
				by djb383
				Three degrees off compared to what????????
				Re: Thermometer Calibration? (djb383)
				Posted: Tue Aug 07, 2007 12:46 am
				by GrayFox
				in this thread
http://forums.genvibe.com/zerothread?id=23081people mention comparing to other temperature readings like the ones on bank signs and such....I'm guessing that's what he's using...
				Posted: Tue Aug 07, 2007 1:20 am
				by kevera
				As long as it's under 5 degrees off,I really wouldn't worry about it too much.
				Posted: Tue Aug 07, 2007 1:34 am
				by nygiantzz1
				It's a simple temp. sensor, no calibration. I think they are fairly accurate. I actually have 2 temp. displays, one is in my auto dimming rear view mirror. I mounted that sensor about 3" from the factory sensor and it consistently reads the same temp. as the factory sensor.
				Re: Thermometer Calibration? (nygiantzz1)
				Posted: Tue Aug 07, 2007 1:36 am
				by Whelan
				Bank sign temps are about 15ft. off the ground.  Next time you have a thermometer in your hand sit in the street, read it.  Then get a 8-10' step ladder, now read it.  There will be a difference.
				Posted: Tue Aug 07, 2007 5:10 am
				by northvibe
				the thermometer is right in front of your radiator so I bet it gets some heat off of that. Some people have moved it off to the side or somewhere further away from the stock location so it doesnt get influenced by the engine heat....
				Posted: Tue Aug 07, 2007 5:19 am
				by trayseelea'sboy
				I would just use a simple correction.  If you think it is off 3 degrees then just subtract 3 degrees when you read it.  If you really wanna check it, you can use an ice bath, but be sure to stir the bath when taking the reading.  Also be sure the thermometer your using to compare it with is more accurate,  (ie. reads to the tenth of a degree).  Any temperature device that reads in °F to the whole number typically has a tolerance of ±2°F.  If it reads in °C to the whole number than the tolerance is typically ±1°C.If you could find the circuit board for the temperature display there may be a potentiometer that you could adjust.PS. I am a metrologist / Calibration technician.
				Temp Sensor Cal.
				Posted: Fri Aug 10, 2007 4:31 am
				by mycar
				Thanks for the replies. It is handy to be accurate as it is a good indicator if roads are close to freezing. Yeah ,I know I can subtract 3 which is what I do, but accuracy is nice.Yes, I have been comparing the temp. display to bank signs. You guys are probably right about engine heat adding to the temp.
				Re: Temp Sensor Cal. (mycar)
				Posted: Fri Aug 10, 2007 4:42 am
				by Kari
				If your car is dark, this probably adds to the heat factor as well.  Mine consistently reads high, but I don't think there is a way to calibrate it.
				Posted: Fri Aug 10, 2007 4:48 am
				by ToolGuy
				My Vibe and Jeep both read high.  I think it is a combination of road heat and engine heat of course strickly speaking when it is not a winter month for me.  The Jeep once climbed crazy high once in traffic and I assume the wind was to blame for that.  Once I drove it went back to where it should have been.  I thought of but never did, making an aluminium heat schield to fit behind the sensor to lessen the engine heat.
