Tyre size
Posted: Tue Jul 31, 2007 8:15 pm
by Zumbi
Can I put 215/60R16 tyres on my Vibe?
Re: Tyre size (Zumbi)
Posted: Tue Jul 31, 2007 8:19 pm
by Raven
Welcome to Genvibe.Those tires are much larger in diameter and are not recommended. Your speedometer will also be way off.
Posted: Tue Jul 31, 2007 8:21 pm
by Zumbi
pity. and what about 215/55 R16
Re: (Zumbi)
Posted: Tue Jul 31, 2007 8:25 pm
by Raven
They are 1.7% different which is alright. The 215/60 were 4.9%. 3% is the recommended limit. Check here.
http://www.1010tires.com/TireS...ubmit
Posted: Tue Jul 31, 2007 8:40 pm
by Zumbi
ok. thanks a lot.
Posted: Tue Jul 31, 2007 9:30 pm
by Sublimewind
Welcome...!!!!You are from Moscow.... Vibes are getting to every corner of the globe it seems...!!!!I bet you don't see many..!!
Posted: Wed Aug 01, 2007 2:53 am
by manicdan
go with 225/50 16s and u will see no difference except the tread wraps around the sidewall a bit, but thats a good thing
Posted: Wed Aug 01, 2007 3:03 am
by BlueCrush
I had 215/60/15 tires on my Vibe earlier this year. There was no rubbing and the speedo was dead on. There were no drivability problem what-so-ever. My speedo was off by 2-3mph with my stock 205/55/16 tires. The 3% rule is a general guideline, not set in stone, and is not the same for every car, wheel or tire. You will be fine with 215/60/16 tires.
Posted: Tue Aug 07, 2007 12:41 am
by ramenboy...
добро пожаловать в семьюi think there's at least a couple more vibe owners from russia on this forum. post pics of your vibe when you can!
Re: (ramenboy...)
Posted: Tue Aug 07, 2007 7:52 am
by Raven
Quote, originally posted by ramenboy... »добро пожаловать в семьюYa, what he said!
