HID Conversion
Posted: Fri Jul 27, 2007 3:23 am
by Big_Red
I did do a search for HID but didn't find anything, so I'm going to ask. I know the Matrix owners have made the switch, but what about Vibe owners? I'm looking for a place in the GTA (Canada) where I can purchase and get them installed at a reasonable price. Any help would be appreciated.
Re: HID Conversion (Big_Red)
Posted: Fri Jul 27, 2007 3:41 am
by 02csnow
Just get in contact with KeithVibe. He can tell you everything you need to know. There are actually threads on here about HID's, you just got to find them.
Posted: Fri Jul 27, 2007 6:00 am
by manicdan
got some hids myself. from oznium.comi dont like them cause even if u get the highbeams working u still cant see anything but what the low beams would have shown you. and for 250$ i would have expected better. but hids alone are awsome light output and color.
Posted: Fri Jul 27, 2007 6:08 am
by Mrizzle05
I actually have all the wires and ballasts and ignitors for a set of HIDs for the vibe, i just dont have any bulbs... : (And i might get rid of my car, so if you find bulbs i can get you the wiring kit for pretty cheap since its just sittin in the garage here. : )i had them on for a while and the output was amazing and they look sooooo good on the vibe.
Posted: Fri Jul 27, 2007 8:29 am
by keithvibe
Quote, originally posted by Big_Red »I did do a search for HID but didn't find anything, so I'm going to ask. I know the Matrix owners have made the switch, but what about Vibe owners? I'm looking for a place in the GTA (Canada) where I can purchase and get them installed at a reasonable price. Any help would be appreciated.You won't find ANY posts with HID, because you need four letters or numbers in the search.What you need to look for is 9003 or H4 hid kits. There are group buys now and again that you can pick up a set cheaper than buying them flat out. Because, the vibe has a bi-xenon bulb:most are a HID low beam Halogen high beam. You will pay more for the kit because of the extra bulb, usually 45-50bucks more for a halogen high beam/ 100-120 bucks more for a HID high beam depending on the kit.I have a halogen type of set up and I am sorry I didn't spend the extra money and get a HID lowbeam HID hidhighbeam.The set up Mrizzle05 is selling would work for you ONLY if you can find matching bulbs for his kit. NOT all bulbs are the same. It's usually paired with a ballast for use with their bulb and their bulb only. SOME, Mrizzle may be one of them that have used other manufactors bulbs with success, but you run the risk of burning out the ballast or bulb pre-maturely, and void any kind of warranty that comes with the set.Do a search under my user name, here and on matrix owners and you will find photos of my set up on my vibe, with before and after photos. I have a close up shot in my signature, both my fogs and headlights are HID.And if you don't know it already. The higher temp number, it ranges from 3000-12,000. 3,000 is yellow 12,000 is purple. If you looking for best visable light output, look at kits between 5,000 and 6,000.
Posted: Fri Jul 27, 2007 10:56 am
by ArcsVibe
Welcome back Big Red! Long time no see I have a seller in Toronto for HID's. I have a pair and they are amazing! Let me know...
Posted: Fri Jul 27, 2007 12:19 pm
by manicdan
arcs, can u go into more detail about the ones hes selling, cause i would seriously reconsider mine if i only knew what i was replacing them with
Re: (manicdan)
Posted: Fri Jul 27, 2007 12:59 pm
by ArcsVibe
Here is his contact info: His name is Dave at
sbisale@hotmail.com just tell him that Sam from the Vibe/Matrix GB from a few months ago sent you!Pictures of the HID box kit are here:
http://forums.genvibe.com/zero...age=5He gives you a 1 year warranty on bulbs and the ballast and it is under 200$ Canadian shipped!
Re: (ArcsVibe)
Posted: Sun Jul 29, 2007 10:38 pm
by Big_Red
Yes, it has been a while, but I'm back...Will e-mail and see what it is all about. I have someone here in the GTA as well, so I want to check it out before ordering.
Re: (Big_Red)
Posted: Sun Jul 29, 2007 11:02 pm
by joholste
hey bud if you're looking to get some HIDs right now there is a GB going on over at MO
Re: (joholste)
Posted: Mon Jul 30, 2007 12:43 am
by ArcsVibe
Quote, originally posted by joholste »hey bud if you're looking to get some HIDs right now there is a GB going on over at MOIt would probably be cheaper and faster since the seller is located in his home province
Posted: Mon Jul 30, 2007 3:01 am
by Big_Red
I'll check it out. I know that they Trix uses different type of lighting (since they have seperate bulbs for high and low beams...
Re: (Big_Red)
Posted: Mon Jul 30, 2007 4:14 am
by joholste
he has the Bixenon HIDs for the Vibe...i'm in on a set of them.
