2.5 Exhaust piping
Posted: Sun Jul 22, 2007 8:17 pm
by vibe Freak
I am going to have a TRD S/C installed. I will be running a JP Performance header as well. What I want to know is 2.5 pipping from the header back to big ? I am planing on running a Magnaflow cat with a Magnaflow resonator and Magnaflow muffler. This will be on a automatic transmission. Thanks for your in put
Re: 2.5 Exhaust piping (vibe Freak)
Posted: Sun Jul 22, 2007 9:24 pm
by Raven
If you get the Magnaflow cat and the full Magnaflow cat-back system you'll be good. You're better off getting the system than piecing together components one by one. I'm not sure what size piping they use but I think it's 2 1/4" which is plenty.
Posted: Sun Jul 22, 2007 10:35 pm
by Sublimewind
Quote, originally posted by vibe Freak »I am going to have a TRD S/C installed. I will be running a JP Performance header as well. What I want to know is 2.5 pipping from the header back to big ? I am planing on running a Magnaflow cat with a Magnaflow resonator and Magnaflow muffler. This will be on a automatic transmission. Thanks for your in putIf you were staying N/A I would say yes, but with the SC it will be fine...
Re: 2.5 Exhaust piping (Sublimewind)
Posted: Mon Jul 23, 2007 5:36 am
by vibe Freak
TUBING KITS COME WITH MANDREL BENT TUBING, HANGERS, FLANGES, GASKETS, NUTS AND BOLTS. THESE KITS HAVE TO BE WELDED TOGETHER OR FOR 60.00 EXTRA YOU CAN HAVE THE HANGERS AND FLANGES PRE-WELDED SO ALL THAT HAS TO BE DONE IS WELD ON THE MUFFLER YOU ARE GOING TO USE.2.25 OR 2.5 INCH, ALUMINZIED STEEL= 125.002.25 OR 2.5 INCH, STAINLESS STEEL= 195.002.25 OR 2.5 INCH, *BOLT-ON*, ALUMINZIED STEEL=185.002.25 OR 2.5 INCH, *BOLT-ON*, STAINLESS STEEL=265.003 INCH, ALUMINZIED STEEL= 150.003 INCH, STAINLESS STEEL= 225.003 INCH, *BOLT-ON*, ALUMINZIED STEEL= 210.003 INCH, *BOLT-ON*, STAINLESS STEEL= 285.00I going to go with there pipping kit an adding my own resonator and muffler and cat. It will be like the JP performance mind pipe only 2.5. I will have the header , mind pipe and then the axle back exhaust.
Posted: Tue Jul 24, 2007 11:39 am
by Lancer
If you go 3" stainless steel, you will be very limited to a muffler that won't sound obscenly loud.Remember, you can't weld stainless to mild steel. Well, you can but it wont last a month.
Posted: Mon Aug 13, 2007 10:32 pm
by drunkenmaxx
2.5 will be plenty. get it done and post it up.
Re: (drunkenmaxx)
Posted: Tue Oct 02, 2007 10:32 am
by vibe Freak
Well I received my VRS 2.5 piping kit today. This Monday I will be down at Pro-muffler having them weld a custom 2.5 Header back custom exhaust... I cant wait .
Re: (vibe Freak)
Posted: Sat Oct 06, 2007 11:55 am
by vibe Freak
The car is an animal !!!! It has so much torque it is spinning the wheels of the line. Who know that all Thas from an exhaust.
Re: (vibe Freak)
Posted: Sat Oct 06, 2007 2:02 pm
by Petrucci914
I wish mine did that.
Re: (vibe Freak)
Posted: Sat Oct 06, 2007 2:08 pm
by BlueCrush
Quote, originally posted by vibe Freak »The car is an animal !!!! It has so much torque it is spinning the wheels of the line. Who know that all Thas from an exhaust. It's actually all from the Helix Power Tower Plus! The Supercharger is just a noise maker.
Re: (BlueCrush)
Posted: Sun Oct 28, 2007 2:08 am
by vibe Freak
Good call Brian. Still working on the exhaust. I will keep you guys up to date on the new exhaust....
