blinker relay
Posted: Sat Jul 21, 2007 10:17 am
by Digger
I picked up some LED bulbs. anyone know if our relay is load limit on the low end is? the LED bulb is 3 watts. Not sure if I will need to get a new relay or use a load resistor to make the blinking work at the right speed.
Re: blinker relay (Digger)
Posted: Sun Jul 22, 2007 10:49 am
by Whelan
One thing is for sure, make positive you put the neg and pos. with the right side of the bulb connector. LEDs will blow in .2 seconds if not done properly.
Re: blinker relay (Whelan)
Posted: Tue Jul 24, 2007 11:30 pm
by 98ex
If your flasher is an 8 pin like the toyotas, then this might work, if not check the site for other versionshttp://frickinbrite.com/catalo...d=296no need for a load resistor.
